I don't know why my pictures are comeing out all big and fuzzy
  • 116 Answers
In the control panel, there should be a setup for printers. Change the resolution on the printings.
Posted on Jul 21, 2009
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
I think I need to clean my print head the pictures are fuzzy I don't know what it looks like or how to clean it.
Hi, You don;t have to take the print head out. Just do a cleaning by ( clicking on printer properties and sellect the maintenance tab and run clean print nozzles). Good luck
Jun 23, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
During night mode only, the picture is coming in fuzzy and very dark, you cannot even see my daughter. It happens when plugged in or not. Day mode is picture perfect
Night mode is for use with a tripod, do you have a tripod? If you don't, try setting it on a flat surface when you take the picture, the camera has to be perfectly still. I hope this helps!
May 31, 2011 | Summer Infant Hand Held Video Monitor
Picture went completely fuzzy. What could the problem be?
The tv CRT( picture tube) have a radiaton posion infected in ur tv picture tube.This is how u discharge the CRT(picture tube) get the posion out.Take the tv back cover off.Take video board that connected to the CRT(picture tube) out.Plug it in,so u have a live current to the CRT(picture tube).Find a wire like an AV cable,should be find.One side of the metal,grounded to the metal frame somewhere.Take a long needle plier grab the other side of the AV cable wire,not the metal,(Caution high voltage live current).Come very close to the open CRT(picture tube).U will have a live current arc,than u,will hear a big "POP".U,just discharge the CRT(picture tube).The tv now the CRT(picture tube),now it good,it clear of posion infected in ur tv picture tube.Now,unplug ur tv.Put ur tv,back together.Hook up ur tv signal cable and plug in ur tv,now ur tv picture,will be clear,completely.I do this many times to dicharge fuzzy CRT(picture tube).When i was a tv Tech.for the SONY TV Corporation.
Oct 12, 2010 | Sanyo HT32546 TV
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
Jul 04, 2009 | Sanyo DP32648 32 in. LCD TV
Tv callibration
don;t know what you mean by they came to calibrate it? if someone worked on it and now it does this then have them come back and undo it
Jul 18, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
RCA Big Screen is fuzzy.
Common problem and RCA recommends the following to cure: replace R17520 with p/n# 218508, C11503 with p/n# 194903, and crystal.
Bill
Dec 12, 2007 | RCA P52937 52" Rear Projection Television
Picture fuzzy on SONY KP-57WS510
Sounds like bad tuner ( it is soldered in ).
I will research part numbers when i get to work today....T.
Nov 01, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Fuji Film Question
The easiest way to tell if camera shake is the problem is to use a tripod - generally not necessary on a bright day, at least with my camera (also a 10x zoom). If a tripod doesn't give you clearer pictures then camera shake is most likely not the problem; if it is, either use a tripod for your big zoom shoots or get used to bracing the camera, either just with your hands held out from your body or against a wall / post / anything handy. Good luck!
Sep 04, 2005 | Fuji FinePix S5100 Digital Camera
Computers & Internet Logo
222 people viewed this question
David Payne
David Payne
