Question about Craftsman 25cc Gas Line Trimmer
Hedgetrimmer won't start
Similar problem but with a hedgetrimmer. Started out pull rope wouldn't recoil, fixed that. Put it back together and noticed leaking fuel lines. Replaced those. Now it will not start. Took carberator apart, checked diaphrams, blew out ports, checked needle and seat. Nothing. Couldn't even get the bulb to pump up. I thought maybe I didn't have the gaskets right below the bulb put in properly.Took carb back apart and switched the gaskets around. Put carb back together. Bulb will now pump up but motor still won't start. At this point I'm not sure about the gaskets or anything else.
5 Suggested Answers
  • 11 Answers
SOURCE: I have a craftsman 32cc
Sounds as if the Carb needs to be cleaned out. Get yourself a can of non-chlorinated brake cleaner and spray the carb out really well. Then reinstall the carb. Also check any ports in the carb to make sure there isn't any debris blocking the flow of fuel. I would also suggest getting some Stabil Marine (blue) fuel stabilizer. The ethanol in gas destroys small engine carbs. Just mix this in with your gas tank the next time you fill up. How old is this fuel? The ethanol also absorbs water, so even while in the gas can it is obtaining moisture. The Stabil Marine formula helps lesson the effects of the ethanol.
Posted on Aug 02, 2010
2strokeJim
  • 577 Answers
SOURCE: my 25cc craftsman weedwacker will
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
Posted on May 18, 2011
  • 1746 Answers
SOURCE: My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Posted on Jun 13, 2011
Testimonial: "Thank you. I had to merely add more gas to tank & bulb siphoned fine. Changed the plug and bingo! It started & runs great. "
philwalker78
  • 608 Answers
SOURCE: I just replaced the diaphrams, needle valve and
Hi, basically the needle in the carby is not sealing correctly. This could be due to the lever height not being adjusted to level with the lower carby body or the gasket not being fitted before the diaphragm on the needle side of the carby. Hope this helps, regards Phil.
Posted on Sep 05, 2011
Testimonial: "Thanks I'll open it up and se what I can do. Is there something I should have replaced where the needle seats / seals."
Pulled starter rope, it's now stuck and won't recoil
Cool!
A Project.
Remove the spark plug lead just so you can't have it accidently fire.
Remove engine cowlings as necessary to get at recoil starter.
Remove recoil starter (that's the bit that the pull rope is attached to.
Dis-mantle it until you can find what is wrong. Fix or replace.
Put it all back together.
or
Take it to a small engine repair shop and pay a bunch.
Mar 06, 2016 | Bolens 31cc 2-Cycle Gas Cultivator BL410
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
Repair weed eater
just apply some oil to the mech.
Jun 05, 2013 | Poulan Garden
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    Recoil pulley assembly keeps binding. Rope stays in pulley, but won't retract. Must remove motor housing , loosen 3 pulley hold down guides, & uncock the pulley. spring tension on recoil is fine....
    Have you ever replaced the recoil rope, if you had is it a larger rope then the one that came with it? If so, that could be the cause of the binding. I had that difficulty once.
    Aug 05, 2011 | Garden
    The cord came out of my Pouland Pro model PPb430Vs leaf blower. I took the unit apart put the cord back on the spool, put unit back together. Pulled the cord but the cord did not re-coil?? What...
    I will give you instructions for fixing the recoil unit on a trimmer. The blower instructions are the same, just the configuration is different. The key is to maybe have someone help you.
    OK...with the starter/recoil unit OFF the machine, with no rope in it, and no tension on it.....grasp the little nylon hub and turn it (clockwise is I recall) round and round 6-7 times until you feel the recoil spring get nice and tight...DO NOT LET GO OF IT!...hold it in place and then JAM the starter/recoil unit in place (still tight) inside it's housing by either clamping it with a tool like vise grips or by sticking a screwdriver thru it and thru the vents in the cover. If you have ANOTHER person to help you...one of you hold it in place....and make sure it is lined up to where you can NOW insert the new lenth of pull rope thru the housing hole and into the hole in the pulley.. Always use new rope....Feed the end thru the hole in the recoil unit and tie it off, by wrapping it around itself outside the nylon hub and then screw the little self-tapping set screw back in holding the rope down. OK...then feed the opposite end into the hole in the front engine cover and attatch the T pull handle....Now mind you, you are still jammming or holding the recoil in place against the spring!...Now, unclamp it or unjam it and slowly let the recoil pull the NEW rope you just installed back onto the pulley. Make sure it is fastened well on top of the pulley around the nylon hub and also fastened well onto the T pull handle. That is it. Then reconnect your wires, put your throttle cable back thru the engine cover and reinstall the Torx screws in the cover...and you are done
    Jun 05, 2011 | Poulan 25CC Gas BlowerVac
    How to put together a toro recoil
    first you put the rope into place then place the spring in the center lock ,if its out then you tighten up the spring by turning it in the direction that will pull rope back in once at the end of recoil send rope into pull hole, hold it tight and let it coil up slowly,reattach to machine and your done.
    Jan 14, 2010 | 2005 Suzuki RM-Z 450
    I have a cub cadet snowthrower 524 (315-616E100), I pulled the recoil starter rope and it broke off in the housing. I opened the housing, restrung the rope, put the housing back on, gave it a pull and the...
    OK, this is a pretty simple fix, if you have 3 hands. What happened when the rope broke is that it allowed the recoil spring to unwind. You need to take the housing off again, put the rope back inside the housing. You then need to turn the big pulley that the rope wraps onto in the same direction as it would turn when you pull the rope. You probably need to turn it 6-8 times at least. Once you get this done, you need to hold the pulley secure and feed the rope thru the housing again, put the handle back on the rope. This last step is where the 3rd hand comes in very handy! This should get you back in business.
    Dec 22, 2009 | Garden
    Craftsman 25cc Gas Line Trimmer Logo
    183 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Jim Parker
    Jim Parker
    Dennis Key
    Dennis Key
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
