Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Does hp88xl black fit with the colors - HP Officejet Pro L7580 All-In-One InkJet Printer
    Problem Solver:
  • 6 Answers
Hp 88xl is the extra large cartridge and it will be comptible with the colors cartridge but the black cartridge should go on the right hand side and the color will go on the left hand side
try this it is going to work...............
Posted on Sep 20, 2009
Can a red drum for an RZ200 be converted to a black drum.
I am am currently not familiar with this model yet. But I have done such a procedure on other models already.
Please consider how to remove the unwanted colored ink. Do you want to dismantle and clean the whole drum mechanism? Or do it by printing several hundred (tousand) prints with high inkage? (You might discover some nice color effects.)
Some questions for you to make it clear: Does the black ink bottle fit in the color drum? Yes? Continue! Compare the PCB (unscrew the plastic housing) of a black drum with a color drum? Identical? Continue! Set DIP switches on PCB like the black drum. You are ready to use black ink!
Apr 27, 2011 | Riso Office Equipment & Supplies
I have a hp officejet pro L7680 all-in-one printer.2007. I got new ink hp 88 combo pack & hp88xl black, but everything prints in pink color where the color part should be what ever the color is on the...
Go into the control panel in windows, select printer and select the properties for your printer.
Push the printing preferences button
Select services
Select service this device.
Press the device service tab.
Run all three tests.
Alignmet, Clean and print a test page.
Jun 28, 2008 | HP Office Equipment & Supplies
Where is the oil filter on this car
if your car from E230 to E500 model diesel or petrol, oil filter housing is fitted let front of engine above the power steering pump, if you remove front section top of engine cover you can see the black color cap fitted on to the filter housing, filter is in it, you must have a right tool for remove filter cap, if your car E200, filter is fitted at left back side the engine it's little deep location have a good look you can see black color cap have fitted there, is this information helped you?
Oct 24, 2010 | 2007 Mercedes-Benz E-Class
Says "NO COLOR CARTRIDGE".
Try this:
According to the Dell website, this is how the cartridges for the Dell All-In-One Printer/Copier/Scanner Model AIO A940/A960 are supposed to look like. (see attachments)
Black cartridge P/N: 7Y743 with U-shaped "lump" on the (black) lid. (equivalent to Lexmark "82")
Color cartridge P/N: 7Y745 with square with corner cutout "lump" on the (blue) lid. (equivalent to Lexmark "83")
BUT, the black Dell cartridges have the identical corner cutout "lump" as their color cartridges. In other words, they have the lid from the color cartridge, but in black instead of blue.
Both cartridges are made by Lexmark and rebranded for Dell. But Dell made the black cartridge intentionally with a different "lump", so customers are forced to buy expensive Dell cartridges.
Stupid actually, because now the black and the color cartridges each fit in the other's slot!
Beat Dell at their own game, don't pay their rip-off prices!
When you open that Dell printer, lift the black lever that closes over the black cartridge. From the underside of that lever you will see a small "pin" sticking out, that corresponds with the corner cutout "lump" (as depicted on the color-cartridge). Cut that pin off with a sharp knife or a wire cutter.
All of a sudden, the cheaper Lexmark "82" black cartridges fit in (and any other remanufactured equivalent).
Money in your pocket!
May 13, 2010 | Dell A940 All-In-One InkJet Printer
Printer won't recognize brand new color cartridge
May 12, 2010 | Dell 944 All-In-One InkJet Printer
Replaced black ink cartridge while printer was off - broke printe
Is the black case broken?Do you try with another black cartridge?If not, try it.You can't put color cartridge in black case.There is an option to replace all carriage unit.Please contact service in your area.
Nov 01, 2009 | HP Officejet 7210 All-In-One InkJet...
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
Cartridge problem
Basically, you placed a black ink cartridge [30] into the compartment for the color one [31]?
Make sure you have a black ink cartridge in the left compartment, and a color one in the right one. I don't even think it would properly fit if they were in the wrong slots. They should "click" into place, confirming that they're installed properly.
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Can I print in Cyan (blue) or magenta?
Depending on which software you are using for documents, you should be able to select output color from within the program; i.e., in Word, you can change the default template to whatever color you wish that is offered on the pallet.
Aug 07, 2008 | Dell 3100cn Laser Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
