Question about Boating
95 Kawasaki 900 zxi, no spark
No spark, have thoroughly inspected all connections, wiring, kill switch, electronic key, inside the electronics box, and have ohmed out the 3 coils, pick up coil, plug wires, all check good. So it looks like the CDI ignitor is bad. But the factory manual doesnt tell how to test it, but to ''take to the dealer for his special tool for testing''. Anyone know how to test the Ignitor? Thanks/
Magneto stator can also be a solution check for AC power from stator while cranking the motor use sta-bil winterizing fluid to insure piston where during cranking process spray directly into spak plug holes with spark plus out 4 sprays into each cylinder should be enough crank motor without plugs for reduced compression and more cranking amps
Posted on Mar 13, 2014
3 Suggested Answers
TechnoMarine
  • 132 Answers
SOURCE: Linear rudder refernce Furuno 500 auto pilot will not pass test?
light on board is probably normal no, this is an inductive pickup, can not test with ohmeter, sorry. Test with display, observing rudder angle display. Do rudder setup repeatedly until it works, it is a little fussy for placement and clearance but patience and the correct "bracketry" will make this pilot perform great.
Posted on Jan 18, 2010
SOURCE: 1981 evinrude 115HP outboard - The wire connecting
1) I cleaned the terminal ends and whether or not I mixed the wires up again, I really dont know but I managed to get the motor started.
2) I took the starter motor apart and cleaned the plates which make contact with the brushes, this made quite a difference to the working of the starter motor.
Posted on Feb 06, 2010
I have no spark on an 86 kx125 upon reassembly.
Hi, Kurt and Tammy some of the following may not apply as this directed mainly towards Harleys what you need is a wiring diagram for your bike which is in the free service manual listed below it sounds like you may have a pinched wire or faulty wire connector or not wired correctly in the ignition circuit, if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
http://vermijsmotorsport.nl/manuals/kx125250-030408.pdf
Kawasaki 1986 Kx125 e1 Kx125 parts lists
http://www.kawasaki-techinfo.net/searchOM.php?view_lang=EN&spec=OC&book_no=&lang_code
Dec 01, 2015 | Motorcycles
I have JD 214 that I've replace coil, points spark plug,wire yet still getting no spark the mower just quit run inspection I found that the points was burnt and plastic where power attached was melted
Wow, a tractor with points. That's rare these days. I believe your tractor was made between 1975 and 1987. It's a 200 series. Does it have the 14 hp Kohler?
Not sure about your problem. On a modern day tractor with electronic ignition, I would check the safety switch system. In your case, I would check the fuse, key switch, and look at the kill wire running off the coils to see if there is worn insulation. If you have seat safety or PTO switches check them too.
You can get parts here:
John Deere 214 Lawn and Garden Tractor Parts
Apr 16, 2015 | Garden
Tiller suddenly stopped. no spark. replaced spark plug, contacts, condenser, coil, kill switch wiring. still no spark. replaced contacts and condenser with solid state electronic unit (Nova II) still...
points? unhook the coil and see if it has spark then. if it does there is a short in wiring to frame somewhere. is there resistance on the pull rope? it is possible it may have broken a connecting rod.
Nov 17, 2017 | Troy-Bilt Garden
1995 Kawasaki Ninja ZX7R no spark
Hi, Daniel and the usual suspects are:
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.zxforums.com/forums/zx-7r-forum/37540-1997-zx7r-no-spark-need-help.html
Kawasaki ZX7 Infamous Grey Wire Voltage Check
97 Kawasaki Ninja 250 Project No Spark Electrical Testing
KAWASAKI NINJA ZX 7R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Nov 10, 2017 | kawasaki Ninja Zx7r Zx9r '94 To '04
Dash lights wont turn on, on a 99 kawasaki 1100 zxi jet ski.
You might want to post this question in a different section. This is the computer games section.
Jul 14, 2012 | Video Game Consoles & Games
1999 kawasaki VN 1500 Vulcan Classic no spark
Hi, Chet and the usual suspects are:
95 vulcan 1500 no spark
How to diagnose no spark situation on motorcycle
Kawasaki VN1500 Service Manual
http://mybikemanuals.com/kawasaki
Dec 19, 2017 | 1999 kawasaki VN 1500 Vulcan Classic
2001 sts 900 kawasaki jetski wont start
Check the engine compression with a compression tester. It should be over 100psi,also check for hot blue spark on plugs,if not blue ignition problem.Weak Spark,but if blue and wont fire with ether the rings maybe worn,and compression to low...Best of luck to you!!!!
Aug 09, 2009 | Boating
Sometimes fires sometimes doesnt
The side stand kill switch can go bad and do this. Check the switch with an Ohm meter. Also, check the wiring harness connections. Fix any loose connections. Check the handlebar kill switch. It can go bad also.
Please rate this answer. Thanks hd87lovetori!
Apr 02, 2009 | 2005 kawasaki KDX 200
Kickstand kill switch inop
Connect the two wires together that goes to the kickstand it should keep it from starting. With wires unpluged it should start.
If that is the case you need a switch
Mar 19, 2009 | 1984 kawasaki Z 650
Boating Logo
784 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
