Question about Mini Motorized Bike
196 cc baja mini bike dies if I try and give throttle
It died all of a sudden an I thought maybe the centrifugal cluth went, but after it cooled down it started back up and will not take the throttle. When I give it throttle it chokes it out. Also after it cooled down and did start for a few minutes the clutch seemed to work properly.
I have a 196cc baja, it has no power going up hills
Posted on Jun 28, 2010
  • 32 Answers
Well i had the same Baja mini bike and to be honest with you, you will run into alot more problems with that bike bec they build them so cheap, I and alot of others had 1 thing go after the other on that modle and to me they just aint worth the trouble or money, But check the coil and make sure to
Posted on Aug 03, 2009
    Problem Solver:
  • 12 Answers
My sons have the same bikes, the problem is in the gas cap the vent hole is to small to allow proper venting when engine is hot. this creates a vacum that will not allow gas to flow properly. You can take the cap apart it has several parts and drill the hole out larger this will vent and prevent the vacum. Hope this helps
Posted on Aug 02, 2010
My Baja 196cc takes off when I start it don't know why just that the bike was given to me recently, no manual
Hi, Jeff your mini bike has a centrifugal clutch and the previous owner may have tried to modify/bypass the governor for more speed if not done properly it will give you the undesired result which can be easily fixed by watching the video below I am sorry you can't find the first and best tool you ever bought for your Baja but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.Mini Bike Easy Governor Bypass 1080P
http://www.bajamotorsports.com/system/documents/86_OWNERS_MANUAL_-_WR65_Warrior_Mini_Bike_US_VIN_prefix_LUAH_.pdf
Mini Baja 6 5hp motor or other problems on 4Strokes com Forums
Jan 01, 2016 | Motorcycles
Subaru ecu
try the crank speed/position sensor as this controls the engine revs as well as other things
May 01, 2014 | 2003 Subaru Baja
2003 subaru 2.5 litre automatic wont start
The hum is likley your fuel pump priming the fuel delivery system. I would start looking at the wiring coming from the Throttle Position Sensor. With the key in the ON position, you should be getting a 12vDC (or a little higher) signal to one wire and an excellent ground on another (usually the center if there are 3). If you are missing a good ground or the 12v signal, there lies your problem. Good luck.
06 artic cat atv 650 h1
Short in dash board, very bad. Contact local Artic cat dealer for assitance
Feb 06, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
I pull start my 49 cc pocket bike and it starts. I lift the back tire off the ground and give some gas its fine. but when i sit on it and give it gas it dies out?
You most likely have oil spilled on the clutch. OR, the carb needs to be opened by 1/4 of a turn on the set screw on the carb.
Aug 21, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
I just bought a 2004 Honda Shadow 600cc that had been sitting for a while. When I pull the choke the engine will idle but as the choke hits the middle the bike dies. also once its running I have to ride...
Sounds like you have a float sticking in your carburetor, is this a single carb or a duel carb? , also gas can go stale and your bike will run like **** if it also has been subjected to tank condensation and water in your gas, that also maybe your problem, I would drain the tank and drain the carb or carbs, and start off with fresh gas and would use 89 octane or better, also pickup some StarTron Enzyme gas treatment, it will stabilize your gas for up to 2 years, and remove the ethanol from your gas, that is a bad for your motor, try it you will never go without it. Good luck, Rick.
Aug 06, 2011 | 2004 Honda VT 600 C Shadow
My pocket bike stops running, and revs by itself
It could be a clog somewhere or he fuel pump. Hope this helps!?
Please rate solution - Thanks.
Apr 20, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Alini pocket quad wont move
Have a look at the choke lever. From the starting position, move the lever about 10mm up until you hear a slight click. If not then the clutch plates are not responding to the throttle input. Any lawnmower repair garage will be able to help you more. The 2 stroke works on centrifugal clutch, that is the clutch plates move outwards when throttle lever is pulled. It is a bugger to start. I've got blisters on blisters from the pull cord. My son is 10 and he may well be a little big for his but when it goes, it is fast enough to start kids off with motor bikes. Hope it helps.
Jan 06, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Mini Motorized Bike Logo
1,842 people viewed this question
Top Mini Sport & Outdoor - Others Experts
Are you a Mini Sport and Outdoor - Other Expert? Answer questions, earn points and help others
