Question about SanDisk Sansa e250 MP3 Player
Connecting to tv
What inputs do i use to connect to tv?
  • 8,596 Answers
Re: connecting to tv - SanDisk Sansa e250 MP3 Player MP3 & Digital Media Players
Headphone jack to r/w audio in, 1-2 jack
Posted on May 25, 2008
0 characters
3 Points
Can i connect my archos 97 cobalt to tv
• Micro USB 2.0: Mobile Transfer Protocol (MTP)
• USB host via OTG
• microSD (compatible with 64 GB cards)
• HDMI output (Mini HDMI / HDMI cable sold separately) If you have the Mini HDMI to HDMI cable you may be able to connect to HDMI input of TV, or try USB out of the device to Computer input on the TV....
Apr 30, 2014 | MP3 & Digital Media Players
How to connect an iPod to a TV
<p>The iPod is a very capable media player personal, but sometimes that tiny screen just does not cut it. Fortunately for owners of iPod, Apple allows users to connect their devices to a TV, so that the videos from your iPod to transmit to the screen. For this connection, iPod owners to buy an extra TV out cable, which is sold in most electronic stores. <br /> <p><br /> <p>1. Buy a cable TV output compatible. Apple sells three TV-out cables, iPod composite cable, composite cable Apple and the Apple Component Cable. See the References section for an iPod TV out cable compatibility list to ensure that you have purchased the correct cable. <br /> <p><br /> <p>2. Connect your iPod to TV out cable TV. Depending on the output cable TV you bought, the cable connects the input of the composite or component input on your TV. Each entry is color coded to the appropriate plug-ins to handle. <br /> <p><br /> <p>3. Connect the other end of the cable to your iPod. The cable consists iPod is connected to the headset connector iPod, Apple, while the other two-plug cables into the wall socket. <br /> <p><br /> <p>4. Turn off the TV mode on your iPod through the opening of "Video Settings" from the "Videos" menu on your iPod and change "TV Out" to "On." <br />
on Aug 09, 2011 | Apple iPod touch
Thomson t3602 manual
DVD players usually connect using either an RCA cable (generally two or three wires, Red, White, and or Blue/Black/Green). The ends look like an umbrella. These are standard connections. Other connections are USB connectors and direct + and - wires. I must assume your is using RCA format. Match the color from the output on the player to input on the TV. That all there is to that!
Dec 25, 2013 | MP3 & Digital Media Players
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
How to install RCA streaming media player on an old TV
I've had a quick look at some instructions online, can't be sure if I'm looking at the same device as you but.
Guesstimating, you're connecting via the composited A/V jack out from your box to RCA (red,yellow,white) inputs on your tv. Or the same but using a SCART converter.
If so, once you've turned it all on, you probably have to change to the correct AV input on your TV. Just keep pressing the AV button on your TV remote control, it should cycle through all the AV inputs until it gets to the one you require.
Apr 28, 2012 | MP3 & Digital Media Players
When i connect my screenplay director to my tv the picture is in black and white, how can i fix this problem?
Confirm that the ScreenPlay Director is correctly connected to video input on your TV set.
Make sure the ScreenPlay Director is connected to power and turned on.
Make sure you have selected the correct video input on your TV to display output from the ScreenPlay Director.
The video output setting on the ScreenPlay might not be correct for your TV. Press the TV SYS button on the remote control repeatedly until the screen displays normally.
Try on a different TV, you TV may not be supported with this device.
Oct 25, 2010 | Iomega ScreenPlay Pro MP3 Player
Ipod vido out
Using the iPod AV Cable
Step 11Use the Apple iPod AV cable. This plugs into the RCA ports on your TV or VCR. This is by far the easiest method. Step 22Connect the AV cable into your iPod. Plug the small end into the iPod where the earbuds would go. Step 33Connect the red RCA plug. This goes into the right audio input of the television or VCR. The colors should match. Step 44Connect the white RCA plug. This plugs into the left audio input of your TV. Connect the yellow RCA plug. This goes into the video input of your TV. Step 55Begin playing a video on the iPod.
May 27, 2008 | Apple iPod MA446LL/A MP3 Player
Archos 504
check the connections again and in settings menu of video recording change the 'input mode' to auto.. if you still cant see the tv output on archos let me know..
Mar 18, 2008 | Archos 504 500870 Digital Media Player
How do I get my Archos to work ont
if you are using an Archos cable, when you plug in to the tv, you should switch to the video 1 or line in source, probably using your tv remote labeled "input"
Dec 05, 2007 | Archos 504 500870 Digital Media Player
SanDisk Sansa e250 MP3 Player Logo
24 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
