Question about Car Audio & Video
Instead of replacing it with a new radio and face plate i heard that i can send it out and have the insides swapped out so i can reuse the original face plate 1963 thunderbird
  • 339 Answers
Here you go:
http://www.casmfg.com/
Custom Autosound Manufacturing does exactly what you are looking for.
Sounds like a great car btw.
Posted on Jul 21, 2009
Problems with monsoon radio in 2002 grand am gt
Try cleannig the contacts with a soft black lead pencil and see what happens
Mar 28, 2012 | 2002 Pontiac Grand Am
The lights on the front of my nightwatch is not working but the rest is the meter and channels light up and the dimmer works just the backlighting wont whats the problem thanks
  • That Night Watch face plate is AC ran by a converter inside the radio. The LEDS are part of the face plate and sold as one unit. The face plate goes out often on these radios. In short the face plate needs replaced if you want it to light up. The radio's performance will not be effected by this. Cobra can actually switch that out fairly cheap. Cheaper than buying a face plate used on the net.
  • https://www.cobra.com/index.cfm
Regards, Tony
May 20, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
2005 subaru outback ll bean edition, center console or "bezel" is one plate with 6 cd changer, heat, etc.. all on same face. 6 cd changer will not work , i have 6 cd's stuck in there, just...
Is car automatic? dont matter, open arm rest and take out every screw u see, dont be scared move foward. pull up on shifter plistic beseil, then to ashtray,2 screws under, coffee thing gotta go.comon guys? can ya get gas in it? its looks like it will brake,just give it a quick ****...
Jan 04, 2011 | 2005 Subaru Outback
I have a Galaxy 99 and I just swapped companies and I now drive a Peterbilt 387. When I plugged my CB in it tripped the fuse. I replaced the fuse behind the glovebox and CB still doesn't work so I am...
The Galaxy DX959 radio requires 12volt DC power. There should be a plastic fuseholder in the power cable near the radio end. There are no fuses inside the radio.
Ascertain that the radio has been connected up with the positive and negative the correct way around before replacing the fuse. Do not bypass the fuseholder or use a fuse with a rating larger than the origianal fuse.
If you have connected the radio to 24volt truck power instead of 12volt power even once you will probably need to send the radio to a competent technician for repair or buy a new radio.
Dec 10, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Need a new face for my cdo cd 1537x car cd player ,danvee@live.com.au
face plates are unique to the original radio you cant replace them its a safety feature for thieft if you lost yours you will have to by a whole new unit
Nov 08, 2010 | VDO Dayton CD4802 CD Player
1963 t-bird radio needs rebuilt/upgraded. who can do this
Yes, this is true, I haven't seen anything on this in a while. The company I remember was in California, They did it with T-Birds, Mustangs, Vettes etc. I will see what I can find. It may take a few days to find, but I will try. Hope they're still in business!
Jun 21, 2009 | Car Audio & Video
Brocken Audiophase CA-813 stereo plate
if your talking about the face of the radio then you'll have to take it to a car audio place and get them to send it away, if you want a new one then you'll have to spend afew more bucks , a new one ( I heard) is about $100
Jun 18, 2009 | Car Audio & Video
BOSE RADIO HEADACHE
what we did was take another radio that had no display but the casette worked so we swapped face plates and installed the radio. We had the luxury of having more than one unit. Thanks anyway.
Jan 08, 2009 | 1996 Nissan Maxima
How i install car stereo in sonata
I have a 2004 Sonata and I'm currently in the process of installing a new stereo system. It's really easy to remove the original radio, you just have to remove the wooden panel face plate that surrounds the radio and air vents.
There are two notches that pretty much lock the face plate on. Right above the ash tray and the bottom of the wooden panel face plate, there's a tiny notch that you can push up on. There's another one that's hidden right above the cigarette lighter. Just push a flat-blade screw driver into both notches and gently push up. Once you lift that up, slowly pull it towards you, and keep prying it open starting from the bottom and moving towards the top. Make sure you pull on it carefully since the air vent ducts and wiring for the fan controls are attached to the face plate. I didn't have to remove the wiring for the fan controls, since I was able to easily move the entire face plate out of the way.
There are four screws that hold the radio in place. Keep in mind, these are screwed in by some machine, so I'd recommend using a power screw driving so you don't end up stripping the screws. Once you remove the four screws you can easily slide out the radio and unplug the wiring harness and antenna.
I searched a lot of places for a converter that would fit directly from the wiring harness in the car to the plug in my new radio, but to no avail. I'm at the point now that I'm going to cut off the original harness in the car and splice the wires, and connect them to the new radio's wires using a crimper. It's really not that hard, but I wanted to avoid cutting and splicing since I previously thought you would lose a lot of sound quality. It turns out, I spoke with several people who did the same thing, and as long as you crimp the wires together properly, you really don't lose out on the sound quality. It's a fairly easy task since all the wires are color-coded, so just match the wires, splice just enough for it to fit inside the caps, and crimp them together.
Then just plug in the adapter into your new radio, screw it in, and you're good to go! I wish there were more adapters out there, but it looks like more and more cars are changing their wiring harnesses, probably to discourage us do-it-yourselfers and pay some insane amount of money to some chump in a dealership garage. Don't be discouraged though! It's really not that hard!
Dec 18, 2008 | 1999 Hyundai Sonata
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
