Question about Kenmore 95032 / 95034 Electric Kitchen Range
What product do I use to clean my Kenmore 95034?
  • yadayada
    yadayada May 11, 2010
    clean what part?
  • 441 Answers
Fofr the top I recomend a smooth top cleaner call cerama bryte, you can get it a any Menards or Lowes, the oven is a self cleaner so I would only use that to clean the oven
Posted on Jul 21, 2009
The oven heating element isn't working, but the broiler is working. The stovetop works fine.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 19, 2011 | Kenmore 95032 / 95034 Electric Kitchen...
My Kenmore Electric range oven will not cut off Model # 790.95201103
I had the same problem with my Kenmore 95662 range. The oven would not cut off. The problem is, the EOC is damaged and probably has to be replaced. I'm buying a new oven.
Dec 26, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
I have model 665 95154 300 I am trying to clean the oven I push clean oven and I get a code E1-F5 what should I do now?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.)(*YIHJ
Jul 03, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
I have an E1 F5 code on my stove and the oven door is locked. What is this code and how do I clear it?
hello,
The E1 F5 is an error code indicating that water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you have to do to fix up this is to unscrew (open)ranger then trace the wire down to the reader sensor/panel clean all form of water and dirt around them after all this make sure that all wire are in there position mostly on the panel then couple it back as it was with this the problem of E1 F5 is solve please do this with care
thank you.
Jun 11, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
I am getting a E2 F2 code on my kenmore electric range model 95014102, pressing the clear button does nothing, I unplugged the stove and the code went out for a few days it is back on. What could be the...
The E2 F2 is an indication that the oven got too hot and shut down. If the oven actually got too hot the issue is most likely the main control board. If the oven did not get too hot the problem would be the sensor.
May 08, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
It makes clicking noises when turned on , but heats and cooks fine
That's just the sound it makes when it turns on and heats up. It is perfectly normal.
Feb 03, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Kenmore 95032 / 95034 Electric Kitchen Range Logo
94 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
