Question about Maytag MFD2562KE Bottom Freezer French Door Refrigerator With Ice Box
Water flow on my Maytag ICE20 is very slow.
Water flow on Maytag ICE 2 O very slow with new filter. Put back old filter and it flow a little stronger but not as strong as when refrigerator was new. Used the bypass and water flow was like when it was new. What is wrong?
  • rhdavila Jul 21, 2009
    Thank you. Tried that but did not stick the toothpick all the way in as I was afraid I might damage something. Can I damage anything or should I stick a papercip inside furtherto see if I can dislodge a clog?
  • rhdavila Jul 22, 2009
    Thank you. Where do I locate the solenoid? Would it be in the back of the fridge?
    President:
  • 2,976 Answers
The orifice into the filter is getting clogged. A toothpick or small paperclip will clear it.
Posted on Jul 21, 2009
  • David Shaub Jul 22, 2009
    It should be an OPEN tube, from the water source to a solenoid and from the solenoid to the ice maker. The only other object is the filter. If you can get to it, check the solenoid for a clog. If it flows on bypass, it is in the solenoid area.
    It should be in back, where the water line goes into the fridge from the supply. They don't make them easy to get to.
How to know the water pressure is wright for Samsung ice maker imc701
Used machine? If new seller needs to help. If under warranty check the MFG customer service number.
If used this may be the reason it was sold. If Used there is a possibility the water filter needs to be replaced. Yes they'[re expensive, but they can interfere with the process. Does the Cold water device work? Is there plenty of flow? If so it's not filter or pressure. If it barely comes out, then it's probably filter and may be the ice maker issue.
Feb 27, 2015 | GE GFSS6KKXSS Bottom Freezer French Door...
How do I fix my water dispenser?
The ice maker would fill slowly even if you only have a "dribble".
It sounds as if your filter light may in error and the filter may need to be replaced. Unless the one your refrigerator uses is very expensive I would replace the filter before calling a technician. If that does not solve the problem, try googling for an answer to your question. Others may have had a similar experience and know the
cause and how to correct it.
May 19, 2014 | Maytag Refrigerators
JCD-23 making too little ice
Check the water flow to the ice maker. Turn the supply water off, loosen a fitting near the ice maker and then turn the water on. You should get plenty of water. If it is slow, check the filter.
Dec 01, 2013 | Frigidaire FRS3R5EMB Side by Side...
Old filter in and water started to sputter, made clunky noises and flow very slow. Removed filter and used plug - water ran fine not filtered.- Replaced with new Maytag filter and water sputtered, flow...
Hello there, when new filters are fitted usually they are expected to spurt for a little bit before they normalize and begin to flow properly. Dispense water continuously for 10 minutes. This usually arises when the flow of water through the unit not being allowed through properly and usually takes the new filter a couple of minutes to get accustomed to the water flow and get water circulating through all its components hence the spurts. Alternatively you can check to ensure that the water supply is turned on full and the filter is properly fitted. If all of these are in place then the dispense mechanism might be faulty.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 23, 2011 | Maytag MSD2756G Side by Side Refrigerator
Icemaker has always been slow. It produces ice, just a couple or 3 times a day. We have to keep our old fridge running just to get enough ice... Cubes are full size, freezer is 0 degrees, not much...
The main reason behind an icemaker to make ice slow is the freezer temperature. It needs to be below 10 degrees. Also check the water inlet valve. Water is controlled by a timer and if its obstructed or slow filling, it will not make ice. You could also have a bad motor, defrost heater, or sensor. If these items fail, it usually won't make any ice. Check to be sure the electric plug from the ice maker is plugged in and check the water flow. However if it is filling up with water or if it just has a small amount in the cube maker. If it's making some ice, it's probably not a defrost problem. Check the voltage to the fill valve. Also replace the freezer's water filter, as clogged filters block water flow. Set the ice maker arm to "Off," and then twist the hanging filter cup counterclockwise to remove it. Rinse the cup under running water and discard the old filter cartridge inside. Slide a new filter cartridge into the cup and reinstall the cup assembly in the freezer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 27, 2011 | Kitchen Ranges
The ice dispenser is making very little ice and the water dispenser has very little water flowing through it
Greetings,
I would check to make sure the water line is turned all the way on...then , check to be sure your filter is not needing replacing. (if you have one)..if these check ok...........its possible your water inlet valve in refrigerator needs replacing...Bruce Denton
Jan 17, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
We have a maytag performa side by side fridge model number psb2151gr the ice maker is not hooked up but it creates ice and collects in the bottom of the freezer and runs out on the floor how do i fix this
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
About a week ago, ice making slowed way down.
changed the water filter. cost $43 for a new one. crazy.
Jun 17, 2009 | Aspen Refrigerators
Ice maker isn't making ice...
there appears to be a problem with 1. the temperature needs to be turned down to produce Ice. also is the fill tube frozen where the water goes into the ice maker sometime you have to thaw it to get the ice out of it and the reset the maker too. Let me know if this helped and if it did not don't rate and ask another question from me and I'll be galad to help. If it did would you please rate this solution please. Thanks for using FixYa.
Jan 01, 2009 | Refrigerators
Maytag MFD2562KE Bottom Freezer French Door Refrigerator With Ice Box Logo
581 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
