Question about Kenwood KDC-C467FM 6-Disc CD Changer
Kenwood 6 disc player says no disc
If open and close door will play first trac then says no disc . I have cleaned checked wires.
  • 2,200 Answers
Hi
The drive is not reading the disk properly. This is either caused by a fault in the laser/lens/drive itself which is leaving the laser misaligned and unable to read the disk or it is caused by dirt in the drive effecting the lens.
There is a Laser cleaning DVD that you can purchase from any audio shop - its not expensive and useful to have around anyway. I would recommend you try a good qulity one such as this from Maxell http://www.amazon.co.uk/Maxell-Europe-Ltd-CD340-Cleaner/dp/B000001OM5
You may find that this will resolve the problem as a simple and quick fix.
If the cleaning disk does not work then the unit will have to go for service repair
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 21, 2009
  • Radio Code Pro
    Radio Code Pro Jul 22, 2009
    Apologies - Line should read - There is a Laser cleaning CD you can purchase - ignore reference to DVD!
I have just filled out a question form before Joining. So here again: It is a need to clean a hi-fi CD playing lens.
It is possible the laser or other part of the CD player is faulty.These can stop working for no apparent reason at any time...
I had a Sony system that also refused to read the cleaning disc. I had experienced laser failure twice before on other equipment and hoped it hadn't happened again as the cost would be disproportionate. This also couldn't be accessed for manual cleaning and so I used a compressed airline and blew through every orifice with the drawer open and drawer closed.
I was lucky and the CD player was again able to read a disc again though a few months later it stopped working again for good. The repair cost would have been half as much again as a new system but I had the remarkable stroke of luck to find someone had put an identical model out for the garbage and so I changed the internals and have continued to enjoy my CD for the last few years, though it is again becoming temperamental.
Sep 21, 2016 | Kenwood Audio Players & Recorders
Stopped playing after I inserted damp CD in 200 disc loading mechanism
this can be due to some moisture in lens.
leave the unit to get dry for 2 days.
Jul 04, 2008 | Kenwood DV-5700 Multi-disc DVD Player
I have a Kenwood music system (quite old ) cd player DP-322 after you load the disc it sometimes just plays 1 track or doesn't play at all if you open the draw and then close it and select random play it...
you need to have the lazer lense cleaned by a pro or buy a lens cleaning cd and load it about 5 times i think youl find it will fix your problem
cheers
sonic boom electronics australia.
Apr 21, 2010 | Audio Players & Recorders
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Cdg player door keeps opening and closing on its own will not play at all
Dirty or bad 'DISC Present' sensor. Eventually the Drive door motor will burn up.
To fix:
You will have to take apart to clean or blast it with pressurized air from side to side thru the opening when it is open.
Mar 26, 2009 | Audio Players & Recorders
Kenwood KDC-C662 6-Disc CD Changer - Error 'T99'
Hi....
Just accumulated dust can cause issues with the reader pickup
I'm not sure what T99 means but if you want to spend $35-90 to fix it,
it would be worth it.
Jan 06, 2009 | Kenwood KDC-C662 6-Disc CD Changer
CD Alarm Clock displays NO DISC when attempting to play a CD.
try cleaning the lense using a cd lense cleaning kit/cd. this usualy helps. if it doesnt work, repost
Dec 18, 2008 | Memorex Audio Players & Recorders
Front door won't open
open the player wit the door ejected then clean all dust particles inside it especially below the door and on the way where the door closes ... and then also clean the rubber belt & near by which is connected to dc motor... and clean the lens also... remember clean only wit dry clothes...
bye cleaning lens it will solve ur playing problems slightly..
and by cleaning near by & bottom of door and door way solves ur half way ejection problem
Nov 07, 2007 | Technics SL-MC700 110-Disc CD Changer
YAMAHA CD PLAYER WON'T PLAY
GG  My kids had a PlayStation 2 that did this and so did my AIWA 3 CD player.  The solution for the PlayStation was to remove the cover use alcohol and clean the lens of the laser reader.  They get dust on them and simply cannot read.  The AIWA required replacement of the laser which cost almost as much as the unit and didn't last 6 months.
Oct 17, 2007 | Yamaha CDC-565 5-Disc CD Changer
Kenwood KDC-2025 won't play CDs
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
Kenwood KDC-C467FM 6-Disc CD Changer Logo
264 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
