Question about LG Prada KE850 Cellular Phone
Deleting Voicemail Can anyone help? I cannot clear my voicemails on this phone. With the network I am with - you are required to dial into your voice mail and then use numbers to save/delete etc and as its touch screen - the numbers arent on the screen - the voicemail dial up number is!! Please help if you can!! Many thanks. K
Re: Deleting Voicemail
Press the hard button which you normally use for switching profiles this will enable the keypad which you can then press the relevant number to delete your voice mail
Posted on Nov 22, 2007
0 characters
3 Points
How to change voicemail on a galaxy 5
  • From the Home screen, tap , then tap Call icon.
  • Follow the tutorial to create a password, record a greeting, and record your name.
Note: These steps may be different depending on your network.
Accessing Your Voice Mail
  • From the Home screen, tap Call icon, then tap Voice Mail icon. You may be prompted to enter a password.
  • When connected, follow the voice prompts from the voice mail center.
Accessing Your Voice Mail From Another Phone
  • Dial your wireless phone number.
  • When you hear your voicemail greeting, press the asterisk key on the phone you are using.
  • Enter your password and you are connected to your Voice Mail.
May 18, 2015 | Samsung Cell Phones
Voicemail number changed on samsung galaxy and can not check voicemail now
Voice mails are set up from the phone company. Your phone has no control over the voice mailing service other than assigning a speed dial to it. You should call your phone company on their customer service number and they will tell your the number to call for setting up your voice mail box.
Mar 11, 2014 | Cell Phones
What button to dial voicemail.
There is no "button" to dial the voicemail. (you didn't read manual).
You access your voicemail by dialing YOUR OWN CELL NUMBER.
(find it here): Menu / Settings / Phone info / Build info / YOUR #.
(copy it down)
If your cell # is: 101-555-1234, DIAL: 1015551234 / hit green phone.
Just follow all the voice prompts to set up your greeting message,
access & delete voicemail messages, etc..
Place it in double parenthesis, just like this: "VOICEMAIL"
When you open phone and hit the contacts button, it will ALWAYS
be the very FIRST contact in your list of contacts. DARN HANDY!!
Jun 30, 2011 | Kyocera Oystr KX9 Cellular Phone
A voice mail has been trapped in the voicemail inbox of my motorola w180 handset. I cant delete it even after a master reset and a master clear. Pl info me how to solve this problem.
have you tried calling your voicemail inbox and deleting it there? normaly a voice mail is not saved on your phone, but at your provider. so you have to call your mailbox as if you want to listen to your voicemails, and there you can choose to hear, to save or to delete it.
Oct 16, 2010 | Cell Phones
Motorola RAZR V3:Can't delete each and every voicemail (new or stored) when directed to press #7. Also can't prevent hearing the date and time for each voicemail. What is the solution?
hearing the date and time for each voice mail is adjusted using your carriers voice mail options. as for deleting each voice mail, it usually requires that you push 7 to save a voice mail and 9 to delete
Sep 07, 2010 | Motorola Mobility RAZR V3i Cellular Phone
How to I record my voice mail message? It says
For most networks in the UK, if you dial your voicemail number, it will start to play your voicemails.
If you have none or if you do then wait until you get to the end, it will then give you a menu. One of those options will be to change your voicemail settings / change you voicemail message.
It varies a little from one mobile network to another, but they are all very similar. The menus are normally easy to follow.
There are often shortcuts to doing this, but the long way is easier to descirbe and works for more networks...
Jun 01, 2010 | Audiovox CDM-8500VM Cellular Phone
When I dial my voicemail it requires a password.
First, try your phone number without the area code. If that does not work, try your full phone number with the area code. As a last resort, try just the last four numbers of your phone number.
If that fails, contact your service provider and request instructions or ask that they reset your voice mail.
Feb 02, 2010 | Cell Phones
How do i set up a voicemail on my nokia N95?
To switch on voicemail you need to dial 1750 this is a free call and to turn off dial 1760
Sep 03, 2009 | Nokia N95 Cellular Phone
Disabling samsung sgh-m140 voicemail
You have to cancel your voicemail service with your provider that is if you are paying for voice mail with anyone. they have to cut it off.
Jun 10, 2009 | Cell Phones
Turning off answering machine
you cannot retrieve messages off the voicemail system I am afraid. If this is down to malicious calls and police are involved speak to O2 as they may have a way to supply evidence direct to police?
Regarding turning off voicemail here are the codes you need, dial 1750 to activate voicemail, 1760 to deactivate voicemail, 901 is used to call in and listen to voicemail and additional options i.e. greeting, pin etc.
WARNING! By turning off voicemail you will ERASE any messages in your voicemail as it resets each time deactivated! So only do this is messages are no longer required!
Hope that helps?
Apr 26, 2009 | O2 X2i Cellular Phone
LG Prada KE850 Cellular Phone Logo
168 people viewed this question
Top LG Cell Phones Experts
Scott Fryer
Steve Sweetleaf
Steve Sweetleaf
Jeremy Murray
Jeremy Murray
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
