Question about Windsor SR12 Sensor Bagged Upright Vacuum
'Bag Full' light indicates at 1/3 bag
As previous poster, with the inclusion that ours goes to full solid light from flashing light, then cuts power to the motor.
I assume this is a feature to get user's attention, but when it is indicating at a non-full condition, gets frustrating.
Had unit open but cannot trace a sensor without a detailed wiring diagram. Only sensor seems to be an electro-magnetic pickup between the motor flywheen and the brush drive.
    President:
  • 2,976 Answers
The sensor is a small hole into the vacuum chamber. It moves the alert system as vacuum inside the unit builds up.
The filtration, built into the bag, is getting filled up and creating a higher vacuum inside the unit, giving a false reading. The only ways to eliminate this are to give the bag a shake to clear some of the dirt out of the filter, try to pick up coarser dirt first or buy generic bags-without the filtration.
Posted on Jul 21, 2009
Fix the yellow flashing light on a numatic hoover ref hqz 250-2
What is wrong with the yellow flashing light? This is a bag full / low air flow indicator. If your bag is not full then you most likely have a blockage in the hose, wand or tool.
Feb 13, 2015 | Numatic Vacuums
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
The red light on my electrolux vacuum comes on and cuts power.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
How to reset?
The button I think you are talking about is the bag switch. It is located in the bottom right corner where you put the bag. If the bag does not cover it, the machine will not run.
Also, when the machine cuts off when the bag is full, you have to push the power switch off and back on to reset the full bag switch located in the switch control housing inside the machine.
Mar 13, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
RENAISSANCE HOSE/VAC
THE RENAISSANCE IS KNOWN FOR HAVING PROBLEMS WITH THE CIRCUIT BOARD IN THE HANDLE.YOU'LL NOTICE THAT MODELS THAT CAME AFTER THAT HAD SLIDING SWITCHES. UNFORTUNATELY THE NEW HOSE DESIGN WON'T WORK ON YOUR MACHINE BECAUSE THE CIRCUIT BOARD INSIDE THE MACHINE WAS CHANGED TOO.AERUS MAY OR MAY NOT STILL MAKE THE PARTS YOU NEED. OTHER WISE LOOK ON E-BAY FOR A NEW HOSE.
ELECTROLUX FOOLISHLY REPLACED IT'S FLAGSHIP STEEL MACHINE WITH THIS DESIGN...A FEW YEARS LATER ALL THEY HAD WORTH SELLING WAS THEIR NAME, HENCE THE NEW NAME AERUS.
Mar 28, 2008 | Electrolux Guardian Bagged Canister Vacuum
Windsor SR12 Sensor Bagged Upright Vacuum Logo
518 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
