Question about LG DN191H DVD Player
I need codes for panasonic tv/vcr. I can get the valume to work but can not get the tv to turn on or off
    Problem Solver:
  • 9 Answers
Pls state the model of the panasonic tv/vcr
Posted on Jul 21, 2009
What is the code for a Panasonic tv/dvd/vhs combo.....
New 3 digit codes for DVD/VCR, DVR/SAT, TV/VCR, TV ...
www.eliztech.com/remotes/ge-new-3digit-combo-codes.php
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
[PDF]Manufacture Code List
https://www.att.com/support_media/images/.../set-up-code-list.pdf
AT&TDVD VCR COMBO. VCR. HTIB. REC TUN. AMPLIFIER. TV. Abex 1098. Admiral ....Panasonic 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289,. 1292 ...
Remote Control Program Codes - FTC - Farmerstel.com
Jan 01, 2016 | Panasonic Televison & Video
Need remote control code
Hello
Three digit universal remote control code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote control codes for Panasonic are:-
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Four digit unversal remote control code for Panasonic TV/DVD/VCR combo is
0437
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR/DVD. Otherwise just the one code operates both the TV and the VCR/DVD.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 02, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
I need the codes to program a panasonic vcr into my toshiba tv remote
The code of panasonic vcr on your toshiba tv are : 14 or 51 and or 59. Try one by one the code above until the vcr work on your TV.
How to do?
1. Press the code button 2. Press the 2 digits code
Regards, Jay
Sep 14, 2009 | Toshiba 50H82 50" Rear Projection...
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Nov 25, 2007 | Panasonic PV-M1349 Combo
LG DN191H DVD Player Logo
164 people viewed this question
Computer Repairing
Computer Repairing
