Question about Ricoh Aficio AP3800C Laser Printer
Ricoh ap3800 I cannot get to print 11" x 17" from bypass trayerror comes up when I hit sendIt keeps telling me to open front of printer to fixI set the bypass tray to 11" x 17"and sent to bypass tray in printer properties
  • 417 Answers
Try sending A4 or letter size to the bypass. if the same problem is risen then you will most likely have a problem with the bypass itself and nothing you have done or are doing.
The other way to check is to set a 11" x 17" in the second tray and try it that way if that goes through then there is no problem with the way you are doing things and the problem lyes with the bypass section.
Please try these and I hope they are of some help to you
Thanks J
Posted on Jan 02, 2008
Bypass tray locked out for printing
Please the copiers models.The paper tray is selected in the computer.To the Ricoh copiers the by pass cassette selected mannually.
Feb 07, 2012 | Ricoh Office Equipment & Supplies
Even though my printer settings are set to print and use the paper in tray 1 - the printer wants to pull from the bypass tray (which always pulls crooked). The printer used to work just fine then the alert...
Two things to check for a problem like this:
1) Driver Settings:
If your computer's drivers are telling the machine to pull from the bypass tray it'll ignore the machine settings. You're kind of on your own here figuring it out, if you can't though then try deleting the printer from the computer and re-installing it (will default settings)
2) Manual Feed sensor:
When you put paper into the bypass try you're activating a flag which tells a sensor there's paper there, if this flag is stuck forcing the sensor to constantly think you have paper there it would always to pull from there. Find the flag, move it back and forth, hit it with some air from a can of air.
May 31, 2011 | Ricoh AficioSP C222DN Laser Printer
How do i connect ap3800 to computer
Depending on how your network is set up, you have a couple options. If you have no network, then you can not print unless the machine is equip with a parallel print connection.
Mar 13, 2011 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Ricoh laser printer will not correctly print my envelopes - need someone to help me calibrate the printer or the word program to effectively print envelopes
what model? you must tell the printer what envelope type is in the bypass (must use bypass) usually type 10. also must tell word in print properties to feed from bypass, again usually type 10 envelopes
Aug 04, 2009 | Computers & Internet
Ricoh SP C410dn Paper only prints 11cm and stops in the Bypass T
do not use ohp film in this device as it will jam due to the use of optical paper sensors unless your ohp has a paper backing. you can set up the bypass tray for thick paper type to increase fuser temp to get better fusing etc
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
HI I am trying to connect my printer via a router
You need to plug your comuter into one of the LAN Port and the Copier into another LAN port your Modem into toyr WAN port. Then you will need the IP of the router it should com along with the router Info and either be 192.168.000.1 or 192.168.0.1. add an ip spec range Isusualle use 192.168.000.120 this goes into your copier under network protacals in user tools. under the same area setup sub net mask 255.255.255.0 if you have already installed you Ricoh AP3800 Driver place the ip 192.168.000.120 again the 3rd set of numbers either .000 or .001 depending on your router. SO under start menu go to either printer and faxes or control panel right click on printer icon for ricoh AP3800 go to properties select the ports tab, Click add Port select Standared TCP ip Clickm the new port. Click next Add your IP adress for the Copier here. Click next Next window will have Generic network card so press NEXT and then Finished Close printer ports window and then click apply. This should get you printing
May 16, 2009 | Ricoh Aficio AP3800C Laser Printer
Printing labels on Ricoh 1224C copier
Labels should only be printed through the bypass tray. when printing, go to "properties", "Paper" and change tray from "auto select" to "Bypass tray"
Jan 13, 2009 | Ricoh Aficio 450 Copier
Printing from the wrong tray on the Ricoh C410 DN
these settings need to be done with the RPCS printer driver, go to properties and then custom settings from there you can tell the printer where to print from.
http://www.websitetoolbox.com/mb/copierquestions
Dec 30, 2008 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
151 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
