Question about Microsoft Windows XP Professional
I believe I picked up a virus that has killed my sound
I picked up a virus a while back that modified some things in the registry. I've gotten everything fixed but one. It has disabled my sounds. I believe I have fixed everything but the sound issue. Basically its telling the computer that there is no audio device installed, even though in the device manager it picks up and understands there is a sound card installed, and states it is working fine. At first I thought it was the sound card, but after pulling it out and trying to use the built in card I realized it was a software issue. I need to know what I need to look for in the registry or where ever on my computer and see what is disabling my sound. My only other option is to format the drive and reinstall windows fully from scratch. And I rather not backup all of my data.
  • Jeff Jul 21, 2009
    Well that won't work since I built the computer back ten years ago. I'm just waiting on Income taxes so I can build a new one. Just rather not waste a lot of time trying to repair this one due to the hardware thats in it.
  • Microsoft Master
  • 5,660 Answers
How about an easier solution? Go to your computer manufacturers website ->Support->Software and Driver downloads, and download the needed audio driver.
Then install the driver. Your audio driver is corrupted, this audio driver download will repair it.
Posted on Jul 21, 2009
  • joecoolvette
    joecoolvette Jul 21, 2009
    I understand. Now how about really learning to build computers?
    A Driver is software that allows 'communication' between a device and the O/S. (Operating System. Example: Windows XP)
    You can download the driver for FREE, from the motherboard manufacturers website. (Support>Software and Driver downloads)
    Your motherboard has a sound chip integrated on the board. The motherboard manufacturer has the driver/s for this sound chip.
    How to find out what motherboard you have? (It's been ten years)
    I advise using Belarc Advisor. It's free.
    http://www.belarc.com/free_download.html
Is Registry Defender safe security for a computer?
It is the "last line of defence" -- if a computer-virus is RUNNING on your computer, you're already COMPROMISED. The software will prevent the computer-virus from modifying the Windows Registry, but at this point, it's already too late.
Feb 02, 2014 | Computers & Internet
Tip
How to remove trojan, spyware, virus.
If you are unfortunately infected with trojan, spyware, virus, security 2010, you can follow this guide to remove them.
First, install an efficient anti-virus, I recommend you AVG. It is free, also it not use much of the memorey space.
Then suggest you download a PC celaner and do a registry scan, Virus always modify the registry making your computer corrupt.
on Feb 21, 2010 | Computers & Internet
Why is adobe flash player crashing everyday?
Quite often you may have to do the removal and restart your PC. Once you have done that, check your registry to make sure you have removed any traces of flashplayer. Before you edit your registry, make sure you back it up first. Should something go awry, you can go back and recover to the back up registry file. Also make sure you do one product removal at a time and check that the reinstall removed all pieces.
May 01, 2012 | Acer Computers & Internet
Exe. files infected xp home edition can run[exe] any remedies
This problem occurs when one ore more of the following conditions are true:
  • The registry values that are associated with the file name extension are corrupted or the values are missing.
  • The computer is infected with a virus.
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows To resolve this problem, follow these steps:
  1. Restart the problem computer in safe mode, and then back up the registry.
  2. Click Start, click Run, type command /c copy %Windir%\regedit.exe regedit.com, and then click OK.
  3. Click Start, click Run, type regedit, and then click OK.
  4. In Registry Editor, compare the following registry subkeys with the registry subkeys of a working computer for the file name extensions that do not open:
    • HKEY_CLASSES_ROOT\.<file_name_extension>
    • HKEY_CLASSES_ROOT\<file_name_extension>file
    • HKEY_CLASSES_ROOT\.<file_name_extension>\<Sub_Folder>
    If you cannot open the .com files, compare the following registry subkeys with the registry subkeys of the working computer:
    • HKEY_CLASSES_ROOT\.com
    • HKEY_CLASSES_ROOT\comfile
    • HKEY_CLASSES_ROOT\.com\PersistentHandler
  5. If you find any difference between the registry entries on the problem computer and on the working computer, restore the default values of the corrupted entries. To do this, follow these steps:
    1. Select the registry entry that you want to change.
    2. On the Edit menu, click Modify.
    3. In the Edit String dialog box, type the value that you find on the working computer in the Value data text box, and then click OK.
If the problem persists, follow these steps:
  1. Note the CLSID number that is found in the HKEY_CLASSES_ROOT\.com\PersistentHandler registry subkey.
    Note The CLSID consists of a long set of numbers that is enclosed in braces ({ }).
  2. Compare the CLSIDs with the CLSID that is located in the HKEY_CLASSES_ROOT\CLSID\<CLSID_number> registry subkey. If these CLSIDs differ, restore the default values of the corrupted entries.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 11, 2011 | Microsoft Windows XP Home Edition
Computer is very slow I had a bad virus so then replaced hard drive with a new one but pc is still slow
Computer slow downs are possible at all times. The only thing required is that the problem should be found and fixed at the right time.
You can scan your computer for errors here
http://www.keep-pc-clean.com/
May 19, 2010 | ASUS P5GC-MX/1333 Motherboard
Is recycler a virus.
Yes it is a virus
1st: Go to Tools>Folder Options>View>unckeck this items below:
1>display the contets of system folders
2>hide extensions for known file types
3>hide protected operating system files(Recomended)
2nd:check all other options in VIEW
3rd:APPLY>OK.
4th:Download unlocker 1.87 ,install it after that enter any drive (C:\,D:\,........) and delete the recycler folder >then a error message will appar and shows that " can not delete RECYCLER:access is denied." it's in use.>click "OK">after that the "unlocker 1.87" will appears automatically and will give options "noaction","delete","rename","move" at down-left corner and there you can select " delete" optinon by scrolling down and after that you can success fully delete the virus,RECYCLER,from that drive.:D
continue this proccess for all drives where you can see RYCLER folder
Jan 14, 2010 | Computers & Internet
I cannot send any e-mails from Outlook, even though I can receive e-mail just fine. Whenever I try to send a message I get the following error: ''A TCP/IP error occurred while trying to send data to the...
To resolve this behavior, either upgrade to the most recent version of Outlook Express and Internet Explorer, or install the version of Outlook Express that matches the version of Internet Explorer that is installed on your computer. Upgrade to the Most Recent Version
  1. Start Internet Explorer, and then download the latest version of Internet Explorer from the following Microsoft Web site: www.microsoft.com/downloads
  2. Follow the download instructions.
  3. Restart the computer after the installation.
Install the Version of Outlook Express That Matches Your Version of Internet ExplorerImportant This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 How to back up and restore the registry in Windows
  1. Use the Add/Remove Programs utility in Control Panel to remove the existing version of Outlook Express.
  2. Delete the contents of the C:\Program Files\Outlook Express folder, but do not delete the folder itself. Follow these steps:
    1. Click Start, point to Programs, point to Accessories, and then clickWindows Explorer.
    2. In the Folders pane, click the plus sign (+) to expand the My Computer folder, and then expand the Local Disk (C:) folder.
    3. Expand the Program Files folder, and then expand the Outlook Expressfolder.
    4. Select all of the files in the Outlook Express folder, and then click Delete.
  3. Use Registry Editor to delete two registry keys:
    1. Start Registry Editor (Regedt32.exe).
    2. Locate the following two registry keys: HKEY_CURRENT_USER\SOFTWARE\Microsoft\Outlook Express HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Outlook Express
    3. For each of the two keys, click the key, click Delete on the Edit menu, and then click Yes.
    4. Quit Registry Editor.
  4. To reinstall Outlook Express, use the Internet Explorer Add a component option in the Add/Remove Programs tool in Control Panel.
Sep 04, 2009 | Computers & Internet
Spysweeper program damaged after a.exe download
isass.exe is registered as the Optix.Pro virus which carries in it's payload, the ability to disable firewalls and local security protections, and a backdoor capability
How Do You Remove Isass.exe Files in Windows XP and Vista:
  1. Click your Windows Start menu, and from “Search,” click “For Files and Folders….”
  2. A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
  3. Type a Isass.exe file in the search box, and select “Local Hard Drives.”
  4. Click “Search.” Once the file is found, delete it.
How to stop Isass.exe processes:
  1. Click the Start menu, select Run.
  2. Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys ALT + CTRL + DELETE or CTRL + Shift + ESC.
  3. Click Processes tab, and find Isass.exe processes.
  4. Once you’ve found the Isass.exe processes, right-click them and select “End Process” to kill Isass.exe.
How to remove Isass.exe registry keys: (Do not delete anything other than what is listed below.)
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any Isass.exe registry keys, select “Edit,” then select “Find,” and in the search bar type any of Isass.exe’s registry keys.
  4. As soon as Isass.exe registry key appears, you can delete the Isass.exe registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete Isass.exe DLL files:
  1. First locate Isass.exe DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the Isass.exe DLL file is located. If you’re not sure if the Isass.exe DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the Isass.exe DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any Isass.exe DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did Isass.exe change your homepage?
  1. Click Windows Start menu > Control Panel > Internet Options.
  2. Under Home Page, select the General > Use Default.
  3. Type in the URL you want as your home page (e.g., “http://www.homepage.com”).
  4. Select Apply > OK.
  5. You’ll want to open a fresh web page and make sure that your new default home page pops up.
Block Isass.exe sites: www.eKerberos.com
Stop Isass.exe processes:
Get rid of Isass.exe DLLs: %PROGRAM_FILES%\ eKerberos\ Hook.dll
Delete Isass.exe folders: %PROGRAM_FILES%\ eKerberos\
Please rate this a fixya
Feb 08, 2009 | Webroot Spy Sweeper (spysweeper) for PC
How do i get rid of a W32.SillyFDC virus
The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
  1. Disable System Restore (Windows Me/XP).
  2. Update the virus definitions.
  3. Run a full system scan.
  4. Delete any values added to the registry.
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
  • Running LiveUpdate, which is the easiest way to obtain virus definitions.
    If you use Norton AntiVirus 2006, Symantec AntiVirus Corporate Edition 10.0, or newer products, LiveUpdate definitions are updated daily. These products include newer technology.
    If you use Norton AntiVirus 2005, Symantec AntiVirus Corporate Edition 9.0, or earlier products, LiveUpdate definitions are updated weekly. The exception is major outbreaks, when definitions are updated more often.
  • Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them.
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
3. To run a full system scan
  1. Start your Symantec antivirus program and make sure that it is configured to scan all the files.
    For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
    For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
  2. Run a full system scan.
  3. If any files are detected, follow the instructions displayed by your antivirus program.
  4. Delete the autorun.inf file from writeable removable devices, if necessary.
Important: If you are unable to start your Symantec antivirus product or the product reports that it cannot delete a detected file, you may need to stop the risk from running in order to remove it. To do this, run the scan in Safe mode. For instructions, read the document, How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [FILE PATH]
Message body: Windows cannot find [FILE NAME]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
4. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to the following registry subkeys:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load"
  5. In the right pane, delete any values associated with the worm.
  6. Exit the Registry Editor.
Dec 18, 2008 | Microsoft Computers & Internet
Dvd dual layer
Hi, Had this problem once in XP Pro SP2 and tried so many remedies which did not correct it. Finally, I found out that my registry was modified by a malicious software (maybe a virus even). It would then possibly be: a modified registry value; a tweaking utility was applied (like Tweak-XP Pro or TweakUI), and/or an update or security software disabled/modified some default features. Of particular interest was the setting at this registry entry: HKEY_USERS\DEFAULT\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer I have attached a screenshot of the current settings/values of this particular entry. Of course, the usual precaution when modifying registry applies - backup, copy old values that you may revert if it does not work, etc.
Aug 15, 2007 | Acer Aspire 1642ZWLMi Notebook
Microsoft Windows XP Professional Logo
422 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
