2004 Jeep Grand Cherokee Logo
Jared Milliron Posted on Jan 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2004 jeep grand Cherokee limited with a 4.7 V8 HO. Do have to put a 4.7 V8 HO engine back in it or can I just put a regular 4.7 V8 in it?
Matthew Spark
Level 3:
Genius:
  • Master 1,066 Answers
  • Posted on Jan 11, 2017
Matthew Spark
Master
Level 3:
Genius:
Answers
1066
Questions
Helped
297914
Points
2431
The HO is a high output version of the 4.7. the differences are internal, the externals *should* be the same.
to be sure, though, call an auto parts store and ask them if the 4.7 regular and 4.7 HO use the same MAIN SEAL. this sill ensure that the regular 4.7 will fit a 4.7 HO transmission, as the main seal comes between the back of the engine and the front of the transmission.
  • Jared Milliron Jan 12, 2017
    What about the computer? Will the computer work properly as well?
  • Matthew Spark
    Matthew Spark Jan 14, 2017
    AGAIN, SEE IF THE COMPUTER PART NUMBER CROSS-LISTS AT YOUR LOCAL AUTO PARTS STORE
5 Related Answers
Anonymous
  • 43 Answers
  • Posted on Aug 03, 2009
SOURCE: Very rough idle on 2002 Jeep Grand Cherokee Limited Edition V8
If you haven't changed the plugs or had the fuel system cleaned, now would be a good time to do it. The number 1 culprit for rough idles is dirty injectors or plugs. You can try an injector cleaner in a can (or bottle) for under $10 and see if it helps, and then work from there. If there isn't any improvement then if you are able to, check the plugs for any gunky buildup and if you find a bad plug, make sure you replace them all (or have them replaced) at the same time.
Anonymous
  • 52 Answers
  • Posted on Aug 11, 2009
SOURCE: 1996 jeep grand cherokee limited v8 5.2, A/C instructions?
  1. Disconnect battery. This must be done to prevent accidental airbag deployment.
  2. Using on A/C recovery unit, remove all R-134a refrigerant from the A/C system. See: Service and Repair
  3. Remove the shift knob by pulling sharply upward.
  4. Place the transfer case in low range. Pry the shift indicator bezel out of the console using a trim stick.
  5. Apply the parking brake and place the transfer case in neutral. Remove the parking brake trim insert. Remove the console attaching screws. Lift the console up and disconnect the 4WD indicator lamp hamess. Remove the console.
  6. Remove the passenger side knee blocker. Remove the single end screw. Remove the screws below the glove box. Remove the screw at the courtesy lamp. Remove the ash receiver and the screws behind it. Remove the instrument panel armature screw behind the ash receiver. Open the glove box and remove the screws behind it. Lower the panel and disconnect the lamp harnesses. For additional instrument panel service procedures to complete steps 6 thru 25, refer to Instrument Panel, Gauges and Warning Indicators/ Instrument Cluster / Carrier/ Service and Repair/ Procedures. See: Instrument Panel, Gauges and Warning Indicators\Instrument Cluster / Carrier\Service and Repair
  7. Remove the pod switch bezels on both sides of the steering column with a trim stick.
  8. Remove the drive side knee blocker. Remove the end screw and screws located at the bottom of the knee blocker.
  9. Remove the cowl top trim panel by prying it up with a trim stick. Remove the solar sensor if equipped.
  10. Remove the "A" post trim panels.
  11. Remove the remove the bolts that attach the lower instrument panel reinforcement to the instrument panel armature and remove the reinforcement.
  12. Disconnect the park lamp switch.
  13. Pull back the carpet at the transmission tunnel from the base of the instrument panel center bezel. Remove the nuts from the upper studs and bolts through the floor that secure the instrument panel center bracket.
  14. Remove the bolts that secure the instrument panel center bracket to the drivers side of the transmission tunnel.
  15. Remove the screws securing the Vehicle Information Center and remove it. Remove the screw fastening the mounting bracket.
  16. Unplug the vacuum harness connector or vent tube on ATC equipped vehicles and the wire harness located under the passenger side of the instrument panel.
  17. Remove the screws holding the passenger side kick panel, along with the screw from the kick panel shroud.
  18. Unplug the antenna cable near the right cowl side panel.
  19. Unplug the instrument panel wire harness connectors from the junction block at the right cowl side panel.
  20. Remove the bolts that secure the instrument panel armature to the windshield fence.
  21. Remove the nuts that secure the top if the instrument panel armature to the windshield fence.
  22. Remove the bolts that secure the ends of the instrument panel to the cowl side panel.
  23. Remove the nuts that secure the steering column to the brake pedal support and lower the steering column.
  24. Remove the bolts that secure the instrument panel armature to the brake pedal support.
  25. Place a protective cover on the seats. Lift the instrument panel off the windshield fence studs and maneuver the instrument panel out and lower it onto the seats.
  26. Disconnect the refrigerant lines from the evaporator tubes. Make sure to install plugs or tape the ends of the lines and fittings to ensure that excessive amounts of moisture do not contaminate the A/C system.
  27. Remove the vacuum line at the tee from the main vacuum supply harness. This line runs through the body with the upper refrigerant line.
  28. Disconnect the heater hoses from the heater core and clamp the ends closed to prevent coolant loss. See: Heater Core\Service and Repair
  29. Remove the coolant overflow bottle.
  30. Remove the Powertrain Control Module with connectors intact and set aside.
  31. Remove the heater A/C housing mounting nuts from the studs on the engine compartment side of the dash.
  32. Remove the heater A/C housing from the vehicle.
  33. To Install the components, reverse the procedure stated above. Torque Specifications: Instrument panel center bracket to floor transmission tunnel fastener: 28 Nm (250 in. lbs.) Instrument panel to windshield fence bolts and nuts: 12 Nm (105 in. lbs.) Instrument panel to cowl side inner panel bolts: 12 Nm (105 in. lbs.) Instrument panel to steering column support bolts: 12 Nm (105 in. lbs.)
Anonymous
  • Posted on Aug 20, 2009
SOURCE: 2005 Jeep Grand Cherokee Limited, 5.7L V8, starter
Every morning at lunch time and evening my jeep won't start. It doesn't grind but the electrical goes crazy. After a couple of trys it finally starts. Help
Anonymous
  • 67 Answers
  • Posted on Dec 06, 2009
SOURCE: how to replace timing cover gasket on a '97 jeep grand cherokee
Pull the alternator brackets and front engine brackets off until you get to the water pump. You will also need to remove the fan shroud and then the fan. Remove the water pump and then you will see an aluminum cover and that will be your timing cover. remove the cover and clean all the gasket off the engine and the cover. use a razor blade, and make sure there in no oil or grease on the parts where the gasket lies. Put your gasket on, bolt the cover back on with the new gasket and repeat the teardown process in reverse.
Anonymous
  • 6982 Answers
  • Posted on Feb 19, 2010
SOURCE: Where is the camshaft sensor located on my 99 Jeep Grand Cherokee
If you still have a cap rotor and ignition wires, it's inside the distributor. If not, it is the part where the distributor used to be (center rear of the engine behind the intake manifold)
2004 jeep grand cherokee 4.7 v8 engine valve cover gasket. i would like to know which company makes the right gasket for that engine
research shows it to be a HO model engine made by dodge /chrysler
so check for ho model engine parts from a dodge spares or a spares shop that has gasket kits for the HO engine
2helpful
Is a 1995 jeep grand cherokee limited v8 vs. inline 6 transmission interchangeable?
No sir they will not interchange. i worked at a transmission shop for 7 years. the inline 6 has a 500 trans in it and the v8 has a 518 trans in it. the bellhousings are different.
I have a '93 jeep grand cherokee limited 5.2 v8.
Disconnecting your battery, as you must've done when changing the starter, will cause the ecu to revert to factory settings and the computer will have to relearn the proper idle for your jeep.
What is firing order
Depend what Engine Model you have:
2001 - 2004 (WG) Grand Cherokee (International Markets)
1999 - 2004 (WJ) Grand Cherokee (All Markets)
WJ engine Specifications
4.0L I-6 1-5-3-6-2-4
4.7L V8 1-8-4-3-6-5-7-2
4.7L V8 HO 1-8-4-3-6-5-7-2
5helpful
I need to know the firing order of my 1995 limited jeep grand cherokeemy spark plug wires are missing i have new wires i just don't know the firing order
For the 1995 Jeep Grand Cherokee:
I do not know if you have the 4.0L In-Line (Straight) 6-Cylinder or the 5.2L V8; however I have included bothe below.
For the 4.0L In-Line 6-Cylinder:
Firing Order:
1-5-3-6-2-4
Cylinders:
(back)
|..6..|
|..5..|
|..4..|
|..3..|
|..2..|
|..1..|
(front)
Distributor:
...(back)
....5...3.(+)-screw
1...........6
(+)4...2
...(front)
For the 5.2L V8:
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
.......(back)......
|..8..|........|..7..|
|..6..|........|..5..|
|..4..|........|..3..|
|..2..|........|..1..|
.......(front)
Distributor:
.......(back)
.........3
...4.........6
8...............5
...1.........7
.........2
.......(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
2answers
Needs new radiator, can you put a 2000 radiator in a 2004 jeep grand cherokee
I want to say yes compare the sizes and the water inlets and outlets to determine if it does. I am sure it will.
1helpful
2answers
1997 grand cherokee limited 4x4 v8
HI, It may seem obvious, but sometimes overlooked.... have you checked the oil level, as low oil can cause some strange things to happen! My 96 4 liter would be reluctant to move sometimes, but after I topped it up, it has been fine.
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
