Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
THE DOOR IS NOT GOING ALL THE WAY UP AND WHEN IT CLOSES IT GOES DOWN AND LIFTS BACK UP HELP!!
  • Don Maggard May 11, 2010
    Have you made any repairs to this or did this just start on it's own?
    President:
  • 3,197 Answers
Loosen the chain and remove it from the sprocket on top of the motor. Then run the opener until the sprocket turns counterclockwise and stops. Now with everything still hooked up and the door in the open position replace and tighten the chain. This should get you close to where you want to be and some minor adjustments of the up and down limit controls should do it.
Posted on Jul 22, 2009
I have a lift master garage door. the door close sometime but sometime will close but pop back up. I have tried to adjust it but it continue to do the same
There should be only 2 things that make it go back up.
First the pressure switch on the door itself. If it is set to low just the pressure from the door closing can set it off. See if you can close the door and use your hands to put some pressure on the door if it goes back up with little pressure then adjust the pressure switch. You might have to turn it a couple of rounds to see a difference.
The other is if you have it installed is the reflective proximity beam on the bottom. Check it and make sure everything is tight and lined up. If it is loose the vibration from the door closing can break the beam and reverse the door. Hope that helps.
Sep 30, 2017 | Building Materials
Inner door glass replacement
open door fully, look down by hinges where enter unit, pull those metal tabs back that lock the door in place, close door to broil position 3/4 way closed and lift up, which should get the door off the unit.. once removed you would have to get acess inside that door by a combination on removing outer sccrews and hing screws and also seperating those glasses.....be careful to remeber how everything goes back i know of some techs that run into problems reassemblin those doors.. hope this helps,, some local service companies often charge a smaller in shop service call for small items like that if thats avaialable in your area,, hope this helps
Feb 07, 2010 | KitchenAid KESC307 Electric Kitchen Range
I have a 2007 yukon and the lift gate goes up about half way and returns to the closed position. What is going on?
try removing your shocks/struts for the lift gate. once removed, check to see if they fully extend in and out of the barrel. You may have bent shocks/struts. Also, check to see there is nothing preventing the lift-gate from opening such as a bolt or acorns between the spoiler and the roof...
Jul 17, 2009 | 2007 GMC Yukon Denali
LiftMaster Gargage door opener problem
The door obstacle detector(reversing switch) needs adjustment, or the down limit sensor needs adjusting, or one of the lift springs is loose or broken. First, remove power from the opener, pull the red door release rope, and try to lift the door up manually. You should be able to lift it all the way open with litle effort. If it opens ok, pull the door down about halfway and let go. If it is properly balanced, it should stay where you left it. If the door fails either one of these tests, it needs spring replacement or adjustment. If the door moves ok, refer to your owners manual on how to adjust the reversing switch, linit switches, and photocell sensors at the door bottom.
Jul 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Subaru door mechanism
okay this how you do it you lift the handle up on the car and you move it back and it should go back only when the handle is up
Jun 20, 2008 | 1995 Subaru Impreza
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
93 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
