Question about Xerox Phaser 6100/BD Laser Printer
Message: waste cartridge is full or not installed
Message will go away if lever is held up so the sensor will read but if you put in a new waste cartridge it will not work? Is the sensor intencity to weak to read through the cartridge?
  • 3 more comments
  • Juize Dec 28, 2007
    Error: Waste cartridge is full or not installed is shown when the cardridge is installed. When it's removed te Error is gone.
  • drobinson001 Sep 02, 2008
    I am having the same problem, even though I ordered a new waste cartridge and snapped it in place - the message is still the same. If I thump the side of the waste cartridge with a finer, the error light goes out and it will print one document, but then the message reappears. Where do I find the sensor to clean or checked for proper seating?
  • stewartj Sep 12, 2008
    Same problem - partially solved by using compressed air solution detailed by fixYa member. However still shows the message when I install the cartridge! Will keep working on it and report back!
  • dbmoving May 05, 2009
    I have the same problem. The display says that the waste cartridge is full, i replaced it and still shows the message. I can pull it out, bring it back to it's position and will make one copy, and then again it says it's full. This is a pain in the ***. I expected more from a Xerox.
  • Anonymous May 10, 2009
    "waste cartridge is full o not installed" won't go away
Hi got the printer as a gift I took the waste tank out and cleaned it with a compressed air The sensor C that the tank is clear (i don't no how) The machine is ready to print but no prints (probably a diffrent problem but the message is Ready all the best Yori Oshri
Posted on Jan 07, 2010
    Problem Solver:
  • 14 Answers
This is a common problem remove the waste toner tank and clean the sensor with air or crc precision clean see this http://www.fixyourownprinter.com/forums/laser/34677
Posted on Mar 23, 2008
    Novelist:
  • 208 Answers
There is a possibility that the Imaging Unit needs replaced.
Or is the sensor itself unseated from its normal operating position.
Posted on Dec 03, 2007
Message reads: wrong cartridge but I have put in 2 new canon cartridges and the message won't go away...getting really aggrevated!!!
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Mar 05, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Waste toner tank full not installed
Behind the waste toner bottle near the top, there's a lever that uncovers a sensor that shines thru the bottle. You can blow out that area with canned air but usually the sensor needs to be replaced.
Feb 17, 2010 | Samsung CLP-550 Laser Printer
Message says; Paper jam. There is no paper in it. Tried turning off and back on, resetting. Nothing, same message. Any ideas? Thanks, Niki
Open the back door and look in the middle of the back cover, there's a black plastic sensor lever that must move up and down freely as the paper passes. That lever gets sticky and needs to be cleaned with alcohol so it can move freely again. You may need to remove the back cover with 2 phillips screws to gain access.
Please rate my response!!
Jan 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Replace waste toner tank message
the sensor for the waste toner cartridge is faulty or the waste toner cartridge is faulty it's self.
Apr 26, 2009 | Samsung CLP-510 Laser Printer
Waste toner box
The waste toner box did you happen maybe break the a small black piece off the waste toner box there is slot for the clear section on the back of the old toner box and you can tell by looking at the machine where the sensor is for that in middle. there should be to the right lower of the machine inside where the toner box goes two slots one handles sensor that tell the copier the box is installed and another for half full box. Have NEW one install it. make sure your toner box has those parts that stick out to accurate those sensors.
Dec 16, 2008 | Konica Office Equipment & Supplies
Dell CLJ 5110
Pop the lens cover off of the transfer roller, clean all the toner debris out of there and replace the lens, put clear tabe on it, and you are good as new!
Oct 09, 2008 | Dell 5110cn Laser Printer
Paper jam error message
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Apr 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Mfc-7220 replaced starter cartridge, new Brother one gives error no cartridge
there is a new toner detect sensor left front upper inside of printer, when a new toner is put in reset lever on cart hits sensor then fall back to front of cart, remove gear asst and put lever in new position, 3/4 the way back. reinsert toner into drum and insert.
Nov 03, 2007 | Brother MFC-7220 All-In-One Laser Printer
Cartridge
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
- unplug cable
- plug cable
Run the software.
oke
Oct 02, 2007 | Canon PIXMA MP160 All-In-One Printer
Waste toner tank full/not install keep displaying
The sensor for the waste toner tank is dirty or defective. The toner sensor is on the right as you look at the panel just below the liquid crystal display. There is a bump in the clear plastic just below the circular right vent port, that's where the used toner pours in. When you clean out the toner cartridge there is some residue left that makes the sensor think it's still full. Take a piece of paper towel and a small screwdriver (I'm told a bent coat hanger will work, too) and clean the inside of the sensor window inside the used toner cartridge (w/ access through the toner port). It looks like a little raised groove on the right. Just wipe it until it's clear on the inside. The sensor can now see through the window and you should be okay. Otherwise, the sensor may need to be replaced by an authorized Samsung technician. Let me know how it works out!
Jun 16, 2007 | Samsung CLP-500 Laser Printer
Xerox Phaser 6100/BD Laser Printer Logo
842 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
