Sounds lie your pressure is ok, but I am curious about the Volume. When was the last time you changed your Fuel Filter? If it is a flex fuel vehicle, and you use a standard gauge on fuel pressure, it will read a bit high.
Second, How old is your battery? Mine did the same thing over the winter, and I found out that my 2000 S-10 only had one replacement battery 4 years ago. It didnt have the Cranking Amps it needed , resulting in hard starts, and low voltage to the Spark Plugs, which made it run rough.
it is a 4 cyl
it is a 4 cylinder, checked the fuel presure it was 52 psi
Is it the Inline 4 or a V-6 engine?
