Question about Powershot Tool Company Tools & Hardware - Others
Easy shot plus staple gun will not open to put in staples. Florida crafter
  • 2712 Answers
SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Posted on Aug 27, 2008
brainyass
  • 242 Answers
SOURCE: LOAD IT
On this model, there should be a spring on the arm. Compress the spring and put the staples in. When you close it, the metal part on the end of the spring holds the staples tight.
_____
I
I
I arm and spring below
I___
___I staples here I_____))))))))))))))))))))))))))))))))))))))))))))))____[___]
Posted on Nov 10, 2008
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
  • 240 Answers
SOURCE: how to remove jammed staples in staple gun?
Pinch the clip located on the end of the Magazine Unit Pull out the Magazine Unit Remove jammed staples from the channel. You may need to use long-nosed pliers . Make certain that you are using correct size staples. Close Magazine Unit.
Posted on Jun 16, 2009
  • 34 Answers
SOURCE: I have a very old Bostitch staple gun Model T5.
You should not need any tools to lift the guard/nose piece. The T5 nose piece cleary has engraved on it "Pull Up To Insert Staples". To remove old staples, use a pencil or similar rod to depress the hammer/striker above the staples while the nose is open.
Posted on Aug 07, 2010
Why won't Easy Shot staples advance/shoot?
Hi Elaine, The EasyShot stapler is a bottom load stapler. Please follow the steps below to make sure you are loading the staples correctly.
- Turn the tool upside down so that you can read the text "use light duty narrow crown" on the bottom of the magazine
- Open the magazine of the tool
- Place the staples inside the channel (not on the back of the magazine rail)
- Close the magazine.
Attached is a picture so you can see where to place the staples.
If you are still having trouble please contact our customer service department and we can assist you further.
customercare@arrowfastener.com
Thanks
May 29, 2015 | Staples Tools & Hardware - Others
How to reload the easy shot stapler gun
While I am not familiar with your brand of gun, almost all of them load in a similar manner!!!!!
At the bottom REAR of the gun there is usually a couple of small tabs [connected together, but one on each side of the stapler body].
With my old Bosch T five tacker and my Swingline machine i push inward toward the front and simultaneously downward releasing th catch and then pull backward on the tab TO OPEN THE MAGAZINE CHAMBER>
Jan 09, 2015 | Tools & Hardware - Others
What Staples does a swingline 34301 Electric Staple Gun take?
That's an easy one
Use the Arrow 600 series staples. heres the link to the different sizes available.
http://www.arrowfastener.com/catalog/supplies/staples/600-series
Good luck and don't forget to rate me :)
Aug 09, 2014 | Staples Swingline® 36115 Staple Guns Tools...
How do i open the stanley tr110 staple gun to load the staples
Angelbabie...Like most things, it's pretty easy if you know how.
1.Release the loading latch located on the back end of the staple gun by pinching it with your thumb in a downward motion. This will release the catch and allow you to pull the loading slide out.
2.Hold the gun upside down (so the staple don't fall out) and place a stick of staples in the bottom of the channel which will be exposed once you pull back the loading slide.
3.Push the slide back in and make sure the latch is engaged. All good to go!
Happy stapling.
Mar 01, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
Every time I load my easy shot 5650 stapler they fall out the end they are supposed to shoot out...why is that ??
The way you load this staple gun is: (1) turn it upside down (2) press the unlock tabs on the rear end of the loading slide trey and pull it back (3) droup a row of staples into the slot w with the pointed end facing up, while keeping the gun upside down, push the spring loaded slide tray forward until the locking tabe engauge. (4) turn the gun rightside up (away from you), and fire it. the stape should come out normally, the rest should not fall out.
Nov 28, 2010 | Comfort LLC Arrow 5650dtc Staple Gun &...
Power shot stalel gun
there should be a silver clip thing thats over the mag that holds the staples try sliding that down and then it should open 4 you
PLZ RATE THIS IF U FIND IT HELPED YOU IN ANY WAY TANKS.
Jul 18, 2009 | Ace Hardware Ace Staple Gun
Can't remember how to load staples in my power shot stapler.
power shot guns have dif crown widths bring the gun to home depot or lowes and match them up or get the model # off the gun
tom
Dec 08, 2008 | Ace Hardware Ace Staple Gun
Putting staples in thew easy shot
Squeeze the plastic clips that are located on the opposite side from where the staples come out. Squeeze and pull straight out. There is a rail inside, where the staples sit. When loading the staples, keep them in the same orientation as they are expected to come out when you are using it (sharp edge down).
Oct 26, 2008 | Comfort LLC Arrow 5650dtc Staple Gun &...
Refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Oct 10, 2008 | Arrow 8000 Power Shot Pro Staple & Nail...
Staple gun support
Aug 27, 2008 | Black & Decker 5700 Powershot Forward...
Tools & Hardware - Others Logo
435 people viewed this question
Top Powershot Tool Company Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Powershot Tool Company Tool and Hardware - Other Expert? Answer questions, earn points and help others
