Question about Samsung HL-P5063W 50" Rear Projection HDTV
My picture won't show after replacing the lamp
Ok well my tv went out a few weeks ago it stop showing the picture but before that it was making a humming noise when I turn it on. Then as time goes by it continue and got even louder then it finally just went out.So now I replace the lamp and now it still doesn't show any picture and the timer,lamp and source indicator are blinking
  • mark_anth908 Jul 22, 2009
    what if its on and all hear is the sound and the lamp indicator is blinking then it will turn off itself and turn back off?
  • colin
    colin May 11, 2010
    sounds like a power supply fault .the protection voltage overload 'trip' is running .i think you need to take this set to an expert as the fault could be difficult to trace....good luck ..
  • 261 Answers
Actually that humming sound was not the lamp, the humming sounds come from color wheels when they're going out, and since the color wheel is part of the light engine system and it's not working, that's why you don't have an image, you'll probably ask your self why, since it's not the lamp.. the thing is that the light engine system is componed by lamp, ballast, color wheel and dmd board, so when one of these doesn't work, there will be no image reflected, because they work together
Posted on Jul 23, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Samsung DLP TV no picture or sound 2 weeks old lamp
Hello, DAvid43, what model is your Samsung DLP tv?
Jun 01, 2008 | Televison & Video
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
I have a 65 inch mitsu DLP, replaced the bulb 6 months ago.. Worked fine until this week.. Now the TV will power up, turn on, then show a picture for a second then go black.. It repeats this nonstop.. ...
Sounds like the Lamp is over temperature. Either the fan went out or the filter is clogged! You might check the filter first. I hope this will help you...
Jan 07, 2011 | Mitsubishi Televison & Video
Samsung HLP5063W no video only sound/replaced lamp 2 weeks ago
With television on and lamp lit, If you hit your menu key does it show a menu. Also just for checking sake if you are using a cable box disconnect it and using the cable coming from wall connect directly to television and try changing the source input to TV on your remote to see if anything is happens, if not then play a dvd and switch source until u hear the sound of the movie u inserted if no video, then its more then likely that the analog/Digital board assembly has failed. I don't know if you vaccumed it before it went out or after but you might want to check to make sure you did'nt hit any cables wires and loosened a plug on any of the exposed boards. If you do find one of the plugs on a board loose or not plugged snuged in its socket make sure u turn off the power first before reseating it. Also if you are using componet input for video or running video through a audio receiver make sure its set to the correct video output source. and that all cables are snug. Especially the green cable on componet inputs. If this cable is loose or comes out their will be no video.
Please feel free to leave a comment in more info is needed..
Lavell
I hope its just something simple
Oct 01, 2009 | Televison & Video
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
60 inch wide screen sony lcd
Symptom shows its Lamp Replacement time in KDF-E60A20 TV
If you have not replaced TV Lamp yet then change it.
Lamp is available in Part Store and lamp procedure is written in User Manual.
Mar 27, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
No picture on my 62" DLP Mitsubishi
I am not sure what the problem is, but usually if a lamp is bad, the other 2 lamps will still function. Since you are getting no picture at all, I am thinking it is a circuit board problem. TV electronics are expected to last 3-5 years. After that, many components will start to go out one by one. If you have your tv repaired, I would replace the whole circuit boards instead of just the bad component. The power board is the #1 board I would replace 1st. This is the most stressed board and will cause most of your tv problems.
Dec 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green power light..no picture
disconnect the power cord overnight try it if ok change power cord cheers
Jan 16, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
194 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
