Question about Toshiba Satellite A105 Notebook
PCI on Motherboard bus 02 device 02
F1 to resume gives the message NTLDR is missing. I need the correct BIOS settings for both the HDD Primary master and the CD ROM Secondary Master
    Scholar:
  • 122 Answers
The BIOS will detect the hard drive and cd rom correctly so at most you should go into the BIOS and select the option to restore optimum settings. The ntldr is possibly the hard drive not being recognized or corrupt data. If the BIOS keeps giving an error the drive is most likely defective and will need replacing, if the BIOS error goes away and the ntldr error is still there try the tips at this link http://tinyempire.com/notes/ntldrismissing.htm
Good Luck
Posted on Jul 21, 2009
Resource conflict error
I would run chkdsk/f on your hdd as errors like this can be caused by system file issues. Go to my computer, right click on drive C and choose properties than tools and then click Check Now. After that run ASC from iobit, a free registry cleaner that actually works!
Mar 23, 2014 | Computers & Internet
Resource Conflict - PCI on Motherboard. Bus:08, Device:09, Funtion:00 / 01 / 02 / 03 / 04
well basically there is something wrong with the system a bus on the mother board is malfunctioning ,well try reinstalling the windows that would usually start the system completely over
Jul 02, 2013 | HP Computers & Internet
Toshiba Satelite M35X-S111 Beep codes on boot
You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
May 28, 2012 | Toshiba Satellite M35X-S161 Notebook
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
Whenever I boot I get the followoing msgs- pri master atapi cd rom primary slave ide hdd primary salave hd smart command failed no 1de master hdddetected press f1 to continue-- then okay But sometimes...
please change the wire connection in your pc from CD rom to HDD so that HDD become primary master and cd rom become primary slave, check after this, and if still get error check your IDE cable, and for the smart command fail may be your HDD didnt support smart feature, so disable this from advance setup
Aug 21, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Printer Driver and Manual for a Canon MultiPass C3000
yedya gandichya driver cd sambhalta yet nahi tar printer kashala gandit ghalayla ghetlas
Jan 03, 2007 | Canon MultiPASS C3000 All-In-One InkJet...
Toshiba Satellite A105 Notebook Logo
155 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
