Question about Nintendo DS Lite
When i turn on my nitendo it says "couldn't find the t/sd card?" what should i do? i use the r4
  • 3 Answers
Turn off your DS, then take out the game. Blow on the metal part of the game and blow into the game slot. Put the game back in and turn on your DS.
Posted on Jul 25, 2009
I bought R4 cards for DSlite and 4gmicrosd formatted sd to fat downloaded kernels for R4 loaded games onto sd card put all together all I get in the Dslite is loading...nothing more it will not go any...
Hi denise, amh, could you please specify what r4 model you got? because there are lot of R4 out there, but the original R4 team had stopped producing R4's, all we have mostly today are clones. now some R4 only recognize up to 2GB of sd/micro sd cards, try using 2GB then see if that works..
Dec 02, 2011 | Nintendo DS Lite Console
Hi when i updated my dsi and then went on my r4i it came up with the following message: an error has occured. press and hold the power button to turn the system off. please refer to the nitendo DSI...
Hi the update has caused the dsi to refuse the r4 card nintendo have put some data in the update that stops you using the r4 cards so your not going to be able to use it, you may be able to do the following depending on what dsi you have got
which kind of r4i do you have?
If you have a R4i golden or R4i-SDHC(red), then you have to buy a new card for your dsi , because two of the cards are un-upgreadeable.
If you have a Hyper-r4i, R4i_CN or R4Ui , then you can download an updater progommen to update your r4i to fit the DSi V1.4 firmware.
Here is a list for Flash cart update:
http://www.4coolday.com/more_news&news_id=25.html
hopefully you can get it sorted you will either need a new r4 card that is able to work with the latest update or follow the instrucions on the links above if your dsi is one listed above
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 29, 2010 | Video Game Consoles & Games
R4 ,When switching on ,SD error shows then
This sounds like a problem with the MicroSD card in the R4. Some brands have been known to be incompatible. Without knowing more information about the R4 and the SD card
A couple of years ago, I had three microSD cards fail, even reformatting failed. I believe it was a problem with the R4's at the time. Try reformatting the microSD card in a PC, download the latest kernel and load that on to the microSD card, if you can get it to format.
Failing that, buy a new SD card. SanDisk/Transcend and Kingston are the preferred and recommended types. Is this an R4 or R4-SDHC? Don't use an SDHC(4gb+) memory card in a R4, only in R4-SDHC.
Memory cards are cheap enough 1gb-2gb don't cost that much, if you have an R4-SDHC then try a 4gb
I take it it was working at some point or other, or is this a new card?
Apr 30, 2010 | Video Game Consoles & Games
R4 couldn t find ds menu dat
Did you install the R4 kernel?
If you didn't click here, scroll to the bottom of the page and download the "English Kernel v1.8" (I'm assuming you want English).
1) Firstly connect your micro SD card and then extract all the files from the zip file and copy them all to the card.
2) Next put your .nds files, mp3 etc. onto the SD card (anywhere in the root of the card is fine).
3) Put your SD card into the R4, pop it into the DS/DSL and that should be it.
Hope this helps, any problems feel free to message me.
Regards,
SOD69
Feb 11, 2010 | Nintendo DS Lite Console
Nitendo DS lite how to play music using R4 revolution DS on my
First you need to make sure you have the current firmware for the R4 card loaded onto the micro-sd card. I know that some R4 cards only accept up to a 2gb memory card so check and make sure you are using the correct micro card with the R4. When you have downloaded the firmware for your card you need to make some folders. Label them games...movies... music... etc.. making a folder for each one. Put the Mp3 files in the correct folder. When you use your R4 you will see three icons at the startup screen go to the one labeled multi-media... Moonshell will run the movies/music... you are ready to go ... hope this helps
Dec 09, 2009 | Lego Media Video Game Consoles & Games
Tried to download software for r4 micro sd card 4gb sh but does'nt work.comes on the ds loading ,works fine with 2gb sd card,any ideas? thank's colin
Hey there Colin,
The original R4 card only works with Micro-SD cards up to 2GB in size. To use Micro-SD cards up to 32GB, you need to buy the newer R4 SDHC card or a Nintendo DSi comaptible card. Check out R4 Cards / R4 DS Cards from DSCardWorld.com or NDS-Gear.com (NDS-Gear is probably better if you live in Europe or Canada as their shipping's slightly better internationally).
Oct 14, 2009 | SanDisk 2GB microSD Memory Card
When I turn on my r4 (2 gigs) there is this weird
put ur sd card onto the computer and make sure the games are still on the sd card, then wipe ur sd card after puttging the games into a separate file on ur compputer.
Make sure they are in .nds format if not they wont work , then downlaod new r4 software and put it onto ur sd card, then make a folder called "games" and put the games back on in the folder called games.
Also if the problem occurred after u have recently downloaded a new game i would delete the new game cos it may have a virus
:) hope this helps.!
Oct 11, 2009 | Nintendo DS Lite Console
Micro sd
have u loaded the r4 soft wear
Aug 12, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
