When I dial a number and press talk I hear a clicking sound with a dial tone then a busy signal sound what can I do I just bought this phone 2 days ago
the number is busy. Try pressing the monitor button and listening for a dial tone. No dial tone means your phone line is not working. If you have dial tone, dial the number you wish to fax and listen to see if it picks up. If you get a busy signal, or hear someone answer, that is why it's not working. If you hear the fax tones, press start and send your document. This is a way to fax that allows you to hear the whole process.
Here are the commands to run the phones memory dial (speed-dial). I have included the instructions for deleting and changing numbers as well. It is listed below. I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS
Store up to ten 20-digit numbers in memory for quick dialing.
Storing a Number in Memory
1. Make sure the phone is OFF (not in TALK mode).
2. Press the MEMORY button.
3. Press a number (0-9) to store the dialed number in that memory location.
4. Press the MEMORY button again.
5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm.
6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number
1. Repeat steps 1 through 4 in Storing a Number in Memory.
2. Press the REDIAL button.
3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number
1. Repeat steps 1 through 6 in Storing a Number in Memory.
2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number
1. Make sure the phone is ON by pressing the TALK button.
3. Press the number (0-9) for the desired memory location. The number dials automatically.
Inserting a Pause in the Dialing Sequence
Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers
1. Press the MEMORY button.
2. Press the desired memory location (0-9).
3. Press the MEMORY button twice to delete the entry.
4. You will hear a confirmation tone.
The dial may be defective and when you dial it is putting out erronous tones. When the Phone Company heres digits that do not correspond to a legal phone number it will give you a error tone or busy tone. It could be the phone got put on pulse and the line won't recognize the pulses
You can activate Call Forwarding whenever you want your calls to be
sent to another phone, including a mobile phone. Once activated, all
your calls will be sent to the forwarding number you request. Each time
a call is forwarded, you will hear one short reminder tone on your home
phone, but you will not be able to answer the call from your home
number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dial tone is OK, but can't dial out • Make sure the tone/pulse setting is programmed correctly. TONE/PULSE DIALING 1. Make sure the phone is OFF (not in TALK mode). 2. Use the CID/VOL left (-) or right (+) arrow button to scroll to 1TONE or 2PULSE, or use the touch tone pad on the handset to enter the desired setting. For example, to choose TONE dialing, press the number 1 key. 1TONE is the default setting. 3. Press flash/program to store selection. You will hear a confirmation tone.
It most likely is the LIU (Line Interface Unit). or you might have it plugged in the wrong port on the fax itself. Make sure it's plugged into the LINE plug. If it's the LIU it would be cheaper to replace then calling for service. Unless it's under warranty still (usually 90 days)
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw)
TONE/PULSE SETTING
1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button.
3. Press * tone button for tone or # pause for pulse selection.
4. Press the program button again. You will hear a confirmation tone.
