Question about Whirlpool Calypso GVW9959K Top Load Washer
Machine won't work it says C1 message. pls advice.
It starts okay but then it stops and says C1 message. what should I do?
    President:
  • 1,776 Answers
On Whirlpool Calypso washers that is probably not a "1" but is the letter i. The code "CI" is the fault code that indicates "Instantaneous Current Limit". Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector (fuse), or motor controller. Overloading the washer may cause this condition. Press stop/cancel to clear the display. Hope this helped you.
Posted on Jul 21, 2009
I keep getting an error message and it stops, Error message C1 and there is nothing with the bobbitn
Try hitting the F8 key after the Laptop starts booting, and when the list of options comes up, select boot in safe mode. If you are unable to get to the options screen, then search on the C1 error code on Google, and look at the tips on resolving the problem.
You will need to make note of the full error code, ie C1xxxxxxx.
Sep 04, 2015 | Computers & Internet
I have sf p120lj washing machine its showing F1 message what should i do advice
I have sf p120lj hitachi washing machine its showing C1 message what should i do advice
Jan 26, 2015 | Washing Machines
Simpson 8.5 kg Eziset stops after wash cycle with error message E20. Am pensioner and unable to move machine. Machine is approx 4 months old. an you assist with advice pls.
If it's only 4 months old it should still be under warranty. Contact the place you bought it from and explain your problem to them. They should repair it at no cost.
Sep 17, 2014 | Washing Machines
Whirlpool Cabrio he washer stopped in drain and spin cycle. Won't drain or spin. drain hose seems clear. Powered off for a few minutes. When I powered on and pushed "start" it poured water in...
You may perform an automatic diagnostic test to check the machine functions and view any saved fault codes. Fault codes may also appear during the test when a problem is detected. Be sure the washer is in standby mode (plugged in with all indicators off, or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, and STOP) and follow the steps below, using the same button (remember the button):
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
The program then automatically checks for saved fault codes. Record the fault codes and post it back.
Press the same button used above in activating the test to advance through the automatic test steps. The basket must be floating in order to agitate. Allow step C1 to complete before advancing to the other steps. Record any fault code shown during the tests and post it back including which step the code is displayed.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Jul 20, 2011 | Whirlpool Cabrio WTW6800W Washer
I have nokia c1-01, i downloaded many themes but when i apply them message occurs theme is corrupt.....how this problem can be fix????
Hi.....
Try the following.....
*Download from www.zedge.com (before downloading select your phone model) and try to install if problem persists.....
Scan your phone and memory card with anti virus
Try to restore settings.....
Thank you
Feb 03, 2011 | Nokia Cell Phones
Andriod.process.acore has stopped message error for a tablet pc
FIRST go to system .manage application.then select all then go to contact storage clear data and after that power off your phone and restart it....
hope this helps...
thank u for using fixya
Nov 11, 2010 | Google Android
I am using Konica Minolta C353. some messages showning in display. ''Malfunction Detected'' Error Message C-3821. Pls advice me what to do? Want to know the problem of the machine.
Your problem in the fuser unit.Clean the fuser thermistors and thermofuses and reset the trouble using the service reset buttom,or enter Stop 0 Stop 001 and select the trouble reset menu.
Nov 11, 2009 | Office Equipment & Supplies
When using the adf get error message
Advice is terribly difficult without a model number of your machine
Mar 06, 2009 | Canon Office Equipment & Supplies
Whirlpool Calypso GVW9959K Top Load Washer Logo
334 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
