Question about Canon PIXMA MP830 All-In-One InkJet Printer
The proposed solution does not work
I am running Vista Ultimate 64 on screaming specs. I have new drivers all around OS, firmware, printer. I have done many things, including changing to plain paper, selecting grayscale, deselecting duplex and borderless printing options, reinstalled the driver, printed offline and turned it on, put in and removed additional tanks.
It will never print from the black only option, even though it is full and the others are empty. I remove them and it will just say I cannot print because of the missing cartirdges in a canon dialoge and bring you to the canon help displaying the status of your cartridges.
I have a 4 year Bachelor in a computer field and have followed all instruction here and elsewhere on the net and achieved no results.
It is a dissappointing to find not only can it not be changed to print using only the larger black cartridges, but in fact as described uses the other 4 smaller more often replaced and therefore more expensive color cartridges. I have this to be true through reading, verified by others posts and in my own experience.
It is not widely known or believed, but there have been linked documents I have seen on certain credible websites that HP at one time or anonther with certain model inkjets engineered a specific part to fail. I am sure it is not the only case, but one I do know I heard of.
We do know for a verifiable fact that they often sell inkjets for less than they cost to produce unlike lasers and that the reason is infact ink. We know they like to not give us cartrdiges with new printers or if they do they are 30% full. We know we also buy a overpriced USB cable to go with it. I do not see it a stretch that engineers designed the printer driver and operation accordingly. This could be easily fixed with a driver patch, given that I have the newest driver, I would bet at a higher level they know about this, probably engineered it, at the support level they are uninformed, misinformed or told to give customers the run around.
I would call support, but I fear I will be wasting my time. This is dissappointing. I stopped buying HP because of the leaked email from a higher up, this may be a reason to stop buying cannon, if they do not have the intiative to address this publicly on this post or since users here have referenced calling support, we know they are aware of they issue, the question is what are they going to do about it?
This sucks. I bought the MP830 because the colors were in different tanks and I thought if I only had to replace what I used, it would be cheaper but if they mash them together to make black, that would be a stretch. Extremely dissapointing.
Feel free to give Cannon this link. I hope they address it, I am not going to waste my time calling them. I do not see why the guy got a 87% approval for his check grayscale box, many users have done that and still the problem exists. Many other places where this is mentioned it mentions a lot more than that and still users have no sucuess.
I believe I tried everything, anything new appreciated. Cannon step up and answer this.
    President:
  • 2,306 Answers
Hi, the MP830 uses the large black for all text jobs, and the software only allows you to use the combined colors for black if you want to stretch the large black ink. If your black is not printing, I would bet your purge assembly is bad or the hose for the black cleaning has come off. I would replace the purge unit,QM2-3032-020 around $20.00
Posted on Jul 21, 2009
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
Lexmark 5400 series model no X5470 is not working with windows 7 ultimate . please give me a solution Amresh Mishra
First, unplug the Lexmark printer from your computer. Then uninstall any existing Lexmark X5470 driver from your computer. Go to Start menu -> Programs -> Lexmark X5400 Series -> Tools -> Uninstall. Uninstall the driver. Reboot pc when prompted.
When your computer turns on, check if your Windows 7 is running on 32-bit or 64-bit service type. Go to Start menu -> right-click on Computer -> Properties. Take note of the Service Type.
Visit the Lexmark website to download the Vista driver. Use the links below:
Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Dec 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Need vista 64 driver for hp 630c printer
Did you check the Microsoft Compatability Listing for the model 630 printer? There may not be a driver for your Vista 64 OS. Search Microsoft Compatability List using your favorite search engine to find the list.
If your printer is listed, great. If not, you will have to go to www.hp.com/support to find a driver. If none is offered there, you can always ask HP. HP responds to public inquiry for drivers if there is enough interest shown. Failing that, you might find 3rd party drivers that may work to your satisfaction. ... and alas, lastly, if you can't find a driver, your alternatives are limited to: Running your printer on a compatable computer/OS, using that computer as a print server on your network or ... purchasing a new printer.
Jan 01, 2010 | HP DeskJet 630c InkJet Printer
Can u please give me the lexmark X1270 driver for windows vista ultimate?
Here is a link to Lexmark drivers for your X1270 printer....are you running 32 bit or 64 bit Vista? None of the drivers actually say 'Home Edition' or 'Business Edition' or 'Ultimate Edition'. Vista drivers are not dependent, persay, upon home, business, or ultimate But Are dependent upon 32 bit OR 64 bit. Both 32 bit and 64 bit drivers can be found here. Hope this helps.
http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_US&question=x1270+drivers&productCode=LEXMARK_X1270&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X1270&searchid=1255871610438#1
Oct 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
I have just built a new custom PC and my new XFX GTS 250 will not work with my Vista Ultimate 64 bit OS but it will work on my Dad's Dell XPS with Vista Ultimate 32 bit! Also his Nvidia 8800 GTX will work...
Your device driver have been tampered with. Check the internet for the driver of your device, download it and install it on your system. You can also use the CD that came with it if any.
Cheers
Jun 27, 2009 | Computers & Internet
My computer is saying no audio output device is installed after applying updates to vista. what should i do?
Hey there, As you have specified the problem, is ocuuring due to driver of your onboard or external sound card device driver is not well in functioning. Sometimes it happens, when you online updates your driver like, your firmware is designed for designated PPI Audio driver while updating online if the exact driver is not found then it searches the driver for related fetched driver for that device. It causes not to let interface your device with the designated OS. Preferred solution: search for any *.nfo file available in your OS Directory(C:\Windows). Open this .nfo file n then look for Audio device version and manufacturer's name. Search the name followed by exact version on http://google.com for OS vista and then install that driver. ##Be sure about the version of OS are you using. like 64 or 32-bit OS. Download the driver with respect to your OS type(32 or 64-bit)## I Hope it will work. Gimme Acknowladgement by rating me. Thanx - Romy Dec
Jun 09, 2009 | Microsoft Windows Vista Ultimate Edition
Unavailability of Data Cards under VISTA BUSINESS 64 Bit OS ??
you can try hp update to be able to run at half the power in order to dlow down and clarify your commmunication
Jan 05, 2009 | Microsoft Windows Vista Ultimate Edition
Canon PIXMA MP830 All-In-One InkJet Printer Logo
121 people viewed this question
old marine
old marine
