Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Our darling grandchild decided to lock our door with us unaware, last night we came home tried to open the door, it tried to go up and down about 15 times. The door will close but won't stay closed and the door won't open completely. HELP!!!!
  • 305 Answers
Check the power supply box for a reset switch, or unplug the power for 5 minutes, that may reset the door
Posted on Jul 22, 2009
Whirlpool Duet. Why is the door locked and will not open?
Try unplugging unit. Powering down often releases latch solenoid.
May 17, 2015 | Whirlpool Washing Machines
When I went out to my 2012 Grand Caravan this morning, my two manual side doors would not open. Everything was unlocked, but neither one would budge.
do your doors lock when you put the van in gear , that is what happened ,when you tried to close the door it released , and now you can open the door,.
Nov 21, 2014 | 2012 Dodge Grand Caravan American Value...
Door wont open on Hotpoint WM51 First Edition
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
In your case you might have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Apr 25, 2013 | Washing Machines
I came home last night and when i enetered in the code to the door, a green light came on in the back of the unit, a noise alarmed and the door did not open. Does that mean that the battery needs to be...
I just had this problem with a model 909. The batteries might be too weak to move the bolt. See if it will move with the door open. Unfortunately, if it's more than a year old, it's out of warranty and no parts are available to repair the electronics. I replaced mine with a different brand, which doesn't drive the bolt, it simply enables the bolt to be moved by hand.
Aug 10, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Neither of our remotes would unlock our doors on our 2003 Silverado Z71 the other day. So we tried by unlocking it with the key. That did'nt work either. Finally, we put the key in the lock and waited for...
TRY Relearning the remotes. to do this get in vehicle with doors closed hold the unlock button down on drivers door while you cut key on and off two or three times you should hear locks cycle and horn chirp. let go of unlock button and hold both lock and unlock button down on one key fob for 15 seconds or so you will see locks cycle move to next remote and do same. then cut key on to exit learn mode. as far as door not unlocking with key this is a problem with lock cylinder most likely.
Feb 16, 2010 | 2003 Chevrolet Silverado 1500
We had a power blink during the night and the next day our garage door wouldn't go down, with the remote or even the house button, unless we hold down the house button until the door is completely down. No...
sounds like a problem in, i want to say the motor, but it opens fine, check your spring assembly, check your chain, and lastly, replace your opener, BUT FIRST, check to see if your garage door opener has a lock feature. most of them do, it disables all wireless remotes. if its only responding to the push of a wired button, then it may be in lock mode, find your manual. the lock button may be on the opener unit or the wall unit
Jan 05, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door remote
It sounds like the lock function has been toggled on. Press and hold the button on the wall control with the lock icon for 3 seconds. This will toggle that function off.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door left open, now fridge won't work right.
Shut down the fridge for 10 - 15 Minutes and leave the fridge door open, and push the Defroce button
ANd start the fridge again and after some time check the temp.+ after some time.
Thanking you,
Your Tech Support
Manish Shirsikar,
Fixya.com
May 18, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
My 1987 Buick Park Avenue alarm goes off for no apparent reason. Up until last night the security alarm was okay. It went off while we were away from home (we found out later). We had just got back home...
Same here. What I do is lock all doors using the button on the driver's door before opening the door, then open the driver's door and lock it manually. That seems to keep it disarmed. I believe it has to be the driver's door for this to work, but I don't know for sure.
Mar 06, 2009 | 1989 Buick Park Avenue
Opener operates on its own sometimes
maybe a short in wall wiring is causing motor to overheat and shut down for 15 minutes. try disconnecting wiring to wall pushbuttons and see what happens.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
138 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
