Question about Maytag Neptune MDE4000 Electric Dryer
Electric Maytag Neptune Dryer not heating up.
The other day we moved our Maytag Neptune dryer to clean out behind it. When we pushed it back in location I noticed that the vent pipe must have gotten dislodged because it was blowing hot air into the laundry room.
My husband looked at the dryer and reattached the vent tube and now the dryer won't heat up. It was working while he fixed it last night, but this morning it would not dry a load of clothes.
Is there something he could have knocked loose from inside of the dryer that we need to hook back up?
Please let me know if anyone has any ideas.
Thanks
  • colin
    colin May 11, 2010
    check the wires to the heating element and the thermostat .if the drum is still rotating he could have loosened a connection.hope this helps if you need more detail send me a picture of the interior. they are very basic to fix ..colin
    President:
  • 1,776 Answers
If the dryer won't heat up, the problem is typically either a blown thermal fuse or a faulty heating element. The thermal fuse is located just inside the back of the dryer on or near the exhaust duct. It is about one inch long. The thermal fuse and heating element can be tested using an ohm meter or multimeter. These components should have continuity. If either does not, that component is faulty. There is no telling if the moving around of the machine caused the problem or if the timing of the problem was coincidental. Sure hope this helps ya and best wishes.
Posted on Jul 24, 2009
No Heat on a Maytag Neptune Electric Dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101\][[
Jul 23, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
My maytag neptune dryer doesn't blow any hot air
on top of the heating element on the left side there is a white 2connector part, that is the heater thermal fuse. disconnect the dryer power cord and one wire of the thermal fuse and use a meter to find out if you have continuity to it. if not replace it. also check for burn wires at heating element. also test heating element by disconnecting one wire and using an ohm meter test it at 2 therminals. it shoul measure 10-12 ohms.
Feb 14, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Our Maytag Neptune gas dryer runs but no heating of the air either on sensor dry mode or timed drying we have cleaned out the lint tripa etc and it does not seem to change anything
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryers I have a Maytag electric Dryer, that...
you may have one of ur overheat sensors going out that wont let the elements heat uplike they should they are behind the back cover they are round and very inexpensive u can take the wires off put new one in or u may have a bad element ake the wires off and check continuity thru the element itsself if all that is good take dryer vent off and run with it off 1 load and seee if this cures the problem if it does u had the hose kinked or u have a restriction of lint in the dryer vent going outside hope this helps
Feb 25, 2010 | Maytag Neptune MDE6700A Electric Dryer
Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
The dryer heats up and spins just fine but doesn't dry clothes, smells like burning
look behind the drier with a flashlight and see if the connecter vent got mashed or folded over when the drier got pushed back also what kind of vent are you using back there if its long cut it short as you need if its folded over on its self that cuts its flow in half
Feb 19, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE4000 Electric Dryer Logo
1,459 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
