Slight fuzziness around edges of print. What is it caused by and how can I eliminate?
  • 42 Answers
Ths is usually caused by the ink cartridge. And you can eliminate it by replacing the ink cartridge or putting tape on it and then ripping it off when your done. Sincerelly Kenny2424 Wiz
Posted on Jul 22, 2009
My tv has a blue blob and slight yellow around the edges what could be the cause of this?
On a projection TV its usually the fluid. On DLP TV sets its a bad color wheel or light engine. At least in most cases
Mar 26, 2012 | Hitachi Televison & Video
Our C9800 Oki laser printer is printing images darker in colour on one side of the page to the other. It looks like it is printing with a lot more yellow on one side. If I send the paper short egde feed it...
What you have here is one of the LED print heads is not sitting correctly on the corresponding drum. Make sure the LED head is free to move and there is no foreign object sitting in/on the drum. Where it is darker the print will be fuzzy around the edges and that confirms what I have said.
Jun 30, 2017 | OKI 9800hdn Laser Printer
I have a Lexmark x543 printer and when I print a document from MS Publisher, there is a small border around the edge of the doc. I have change my printer settings to Whole Page printing but it does not...
try to print a test page .. if u get the lining there then its a problem with the printer drum .. u might need to get it replaced .. if not then its an issue with the settings .. you can also try to reinstall the drivers in that case.,
Oct 21, 2010 | Lexmark T632 Laser Printer
Oil leak and orange oil light stays on briefly after starting up, also slight water leak. i suspected head gasket at first but eliminated that after the combination of these two faults causing fluid loss....
why eliminate head gasket? head gasket failure can cause loss of both fluids. i suspect the oil light is lost oil pressure because the head gasket is toast or the head is now warpped and thus leaking. you should be able to see signs of leakage around the head.
do you see any oil getting into your rad? if not then the oil must be leaking around the head.
Mar 05, 2010 | 1998 BMW 3 Series
Black edges to individual lcd cells
Sounds to me like the screen is starting to go bad. Best way to find out though, try another known working monitor and see how that works. If the other monitor works well then you know the original monitor is the problem.
If the 2nd monitor gives you problems then you know its the video card thats bad at that point cause you would be having the same problem on both computers.
Jul 04, 2009 | Dell ? SP2009W 20" Widescreen Flat Panel...
Blurry print on Minolta Bizhub C350
CLEAN LASER UNIT ON THE DOOR U HAVE STICK AND PADS FOR CLEANING
Apr 09, 2009 | Konica Minolta Office Equipment & Supplies
Repacing the color inks with black ink on the epson 1290
Well, since you say you'll be using new cartridges you shouldn't have any nozzle problems. About the worst case I can see would be the slight chance of getting too much ink on the paper resulting in wet paper and a stained platten roller. Seems like an interesting experiment over all.
Nozzle problems arise when reusing cartridges. The very thin metal film that is the nozzle assembly gets worn down as the print head moves over paper and after a number of pages printed the little holes that are the nozzles get larger making for fuzzy, wetter than it should be, streaky printing.
Enjoy,
Carl
Dec 14, 2008 | Epson Stylus Photo 1290 InkJet Printer
Picture quality
Try cleaning the lense. May have smudged finger prints that cause light diffusion. Cheers
Aug 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Xerox 8550DT
this is usually caused by a fuser but could be static from the paper depending on the fuzziness. if the letters have like a halo effect around them then it could very well be static and you may want to try a fresh **** of paper. otherwise, it probably the fuser...
May 08, 2008 | Xerox Phaser 8500/DN Printer
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
jasbo
jasbo
