Question about HP OfficeJet 6110 All-In-One InkJet Printer
I don't know how to get out my ink cartige
I dont know where to open my printer to get my ink changed. also it said low ink but when i printed nothing was on the paper. also i dont know if im putting the paper in the proper place. Please help me !!!
    President:
  • 3,085 Answers
Paper goes in the bottom tray in between the guides.
There is a handle just above the paper tray to open a door for changing cartridges.
Posted on Jul 21, 2009
Fix-ya
This sounds odd. Anyway, if printer prints, there's nothing wrong with printer detection.
First and foremost, what type of paper and color of paper are you using? What text/image color do you have in your file being printed?
Aug 28, 2014 | Canon PIXMA MP495 InkJet Printer
My "ink not sufficient" button is blinking but the
Hello
I believe the ink cartridge should have ink but not sufficient for printing, if the cartridge is expensive why dont you re-fill it, re-filling is very low cost option.
Also clean the contacts of cartridge from both ends.
Hope this helps, if so do rate the solution Good Luck
Jan 11, 2011 | HP DeskJet 990cxi InkJet Printer
Epson Stylus C84 prints every other line.. Cleaned print heads and ran nozzle check...still same problem.
Your printer head may be booked. Follow the instruction given bellow:
1. Open printer cover and put off cartige from cartige chamber.
2. Take a plastic seringe with full of ink and fit it on head's stick. Then push ink carefully.
use this procedure one after another . I thing you may relive from your problem. thank you.
Aug 17, 2010 | Epson Stylus C84 InkJet Printer
Cartrige error 1203, what do I do to solve this problem?
It seems your courtige do'nt support in your printer. To continu your printing you need to replace ink cartige. In older cartige you may try the following tecnique:
1. Open your unsupported in cartige.
2. Take a pice of tissue paper and wip smothly both the connector plate and cartige head.
thank you.
Aug 17, 2010 | Lexmark X7170 All-In-One InkJet Printer
Why does my printer notrecognize the ink?
follow the mentioned procedure:
1. click start manu
2.open fax and printer
3.double click the effected printer icon
4.there will be show some print order, delet all the print order, then restart your printer.
solution-2
if you use continuous inking system, push out all the ink cartiges from the chamber. then clean the conected area and set the cartige again perfectly.
Feb 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I got my ink cartridge refilled but it's still saying its empty, how do i get it to print anyway?
So as MUKHTAR states, do not refill cartiges when they are TOO EMPTY as most of the new printers have a sensor in the cartige that tells when it is empty. and when that sensor fills that the cartige is empty, it stays that way, no matter how much you refill it.
on the laser printers, when you refill your toner cartige there also is a chip that is changed (the sensor) because once that sensor feels that the cartige is empty you will not be able to use that cartige anymore.
Nov 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Yellow ink is not printing properly
i think your cartige yellow ink had finished or dried up what u can do is refill yellow ink or dip cartige into hot water.... and clean it nicely it works
May 20, 2009 | Canon Pixma iP4500 InkJet Printer
Can you tell my printer cartiges was finish i refil new cartige and put in the printer but printer does not work only for printing from computer but fax is working photocopy is work and sccaner is also...
Please follow these tips
1. turn off your printer for one menu t and then turn it one.
2. You should charge your ink the option may be in your Pinter software or there should a button in your
Pinter to charge your ink.Press
OK to begin charging the ink.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}you need to disable the ink level monitors afterre-filling the cartridges. go to properties, maintenance, view printer status,option and click enable status monitor once
Nov 22, 2008 | Lexmark Office Equipment & Supplies
Change ink cartigates and will not print
oke dear
you can try this site
THE SERVICE MANUAL FOR YOUR PRINTER *step by step instructions in repairing it) is here
http://www.nodevice.com/manual/Canon/page15.html
and here
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
oke
Mar 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Not Printing
the problem you all have could be from the ink cartige or from the ink cartige holder , take out the cartige from the printer , if you can take out the cartige holder out too , spray the cartige holder with a glass cleaning solution so it pours out from its bottom side , spray the ink cartige bottom , wipe it with a tissue then swing it hardly downwards so ink is poured from its bottom then wipe it with a tissue .
Oct 17, 2007 | Office Equipment & Supplies
HP OfficeJet 6110 All-In-One InkJet Printer Logo
71 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
