Question about M-Audio Audiosport USB Duo External Sound System
The input is just making noise, how can i fix it?
  • 83 Answers
Try a reset to factory defaults if was working before!! Tf not working ever refer to setup settings for input device !! may need to be serviced !!
Posted on Jul 21, 2009
TV is making loud whistling noise
If you have a spare cable set, try using this in place of the existing one. Is it only one of your inputs that is doing this? If you have 2 inputs that are connected, first try switching the cables. If this doesn't fix it then it is either a problem with the tv or the input device. If the problem moves to the other input then you need to replace the cable. If switching cables doesn't work, switch to a different input. If this fixes the problem then there is an issue with the input on your tv. If neither of these fixes the problem then it is most likely a problem with your device.
Most likely there will be a problem with your cable connecting the device to the tv or with the connection between the cable and the input. If you think that it is a problem with the tv (ie. the female input socket) then I suggest getting it repaired (expensive I know) or you might be able to get a friend who is good with electronics to take a look at the connection.
Nov 30, 2013 | Aiwa F2000 20" TV
My roland cube street starts making this really weird loud noise
Hi, Quick Check. Very often the input socket which is soldered directly to the circuit board, will have a broken solder joint. This is common on a very large amount of equipment. Try waggling the plug about and seeing if the noise comes and goes.
Easy fix, re-solder joint. Permanent fix, connect socket to board with flying leads, or fix socket to board with hot glue or epoxy resin.
All the best, Chris the Fader.
Mar 23, 2013 | Roland CUBE Street Amp Combo
Speed sensor of DC Motor treadmill making noise.
the speed sensor NOT make noise, is the main motor see the diagram attached.However tight any connector or plug very well, and test the s. sensor for open or defective and replace. You can RUN the software calibration for easy diagnose, troubleshooting, and fix it.
You must test the input voltage motor, if there are the motor need repair, bearing, shaft, or winding defective.
God bless you
Nov 18, 2012 | Precor C966i Treadmill C 966i
Why is my speaker making a beeping noise
It may due to fellow problems:
1. device interface
2. Input and wires
3. Some popping noises have to do with internal components of speakers systems that can only be fixed by those with advanced knowledge of the technology. If the above methods don't work, consider hiring a technician to diagnose your system.
Aug 13, 2012 | 2006 Kia Sorento
Sanyo dp42841 is making a crackling noise
determine first if with sound off you have the problem---if not it is audio related and if with sound off it is still there it is inside the set....
Mar 29, 2012 | Sanyo Televison & Video
Bose lifestyle makes loud noise like a build up of
If you still have the speakers that the TV came with hooked up try unhooking the wires to them I had the same problem and it fixed the problem, Good Luck!
Apr 10, 2010 | Bose Lifestyle 28 System
Has a noise at idle,like a noisy input bearing to the gearbox, if I push the clutch in the noise stops. but the noise is not there all the time, I can make it make the noise, if I depress the clutch a few...
Throwout bearing is going out so it means you would have to remove the transmission, and also could have a bad pilot bearing out and or a broken clutch spring so it would still need to remove the transmission to fix it and then If it where me I would do a clutch job on it.
Jan 24, 2010 | 2001 Isuzu Rodeo
No picture, sound works, but along with high-pitched noise
My guess is that you might have the yellow (video) cable plugged into an audio input on the TV. Make sure that the yellow cable is plugged into both the video out on the DVD player and the video in on the TV. Most of these connections are color coded.
As a diagnosis, try changing the TV input (using the remote) and let me know if you still get the buzzing on the other inputs. If no, then, it's most likely your RCA connections. If yes, it's another problem.
Apr 21, 2009 | ViewSonic N3252WS 32 in. LCD TV
Cable connection generating static on screen & noise
Hi, it sounds like ya most probably gonna haveta resolder the Cable Connection Socket internally.. they often fracture, OR perhaps it is the Actual Cable Connection Plug itself?.. maybe you need to remake this input connection? Indeed it sounds as if the Earth Shielding is making bad contact...
Sep 04, 2007 | Toshiba CF36G40 36" TV
M-Audio Audiosport USB Duo External Sound System Logo
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
