Panasonic CD PLayer SL-CT520 Rechargeable AAA Batteries
I am having trouble in finding the right rechargeable batteries for my Panasonic CD player SL-CT520.
The ones recommended by Panasonic are "NI-MH RECHARGE BATTERIES HHR-4AGA/2B" which recharges within the CD player itself with the help of a DC Adapter.
Kindly Suggest if I can put NI-MH Batteries of any other company and have them rechagred in the CD player Body itself, without any need of buying an extra charger.
The batteries available in the market are "Panasonic HHR-3HPA", if I buy these will they be compatible with my CD player and charge in the Player unit itself with the DC adapter power.
  • Anksh08 Nov 22, 2007
    I bought a Pair of Panasonic AAA Batteries HHR-3HPA 1350 mAh but it didnt show charging within the unit :(
    Has to buy an extra charger too.
    Don know why panasonic will device such a unit which doenst charges even their own battery.
Hey this is RaulFixall. You can fix this problem by naking the batteries, I'm mean by taking apart the plastic that cover them. You'll see that the led charging will turn on.
Posted on Jan 03, 2009
Dear Anskho8,
The best guide for batteries is the type Size, voltage, and capacity in milliampere hours. as long as this specifications match you can always interchanged them. However you should buy the same type and quantity per batch, do not mixed them up.
Also make sure these are NI-mh types.
sid
Posted on Nov 21, 2007
Which batteries should be used with the Philips cd155 cordless phone
Hi
The batteries to be used are:
Nickel metal hydride rechargeable batteries, AAA size. These are nominally 1.2 volt usually and are widely available in electronics shops, and on the Internet. eg here:
Panasonic Evolta NiMH Ready to Use Rechargeable 750mAh AAA Batteries 4 Pack
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 20, 2014 | Philips Lands Phones
User manual
The RD1072 uses standard AAA batteries, disposable or rechargeable. If you want to use rechargeable batteries, you must charge them outside the player using a separate battery charger.
You may view/download a copy of the manual at http://www.fixya.com/support/p211513-rca_lyra_rd1072_256_mb_mp3_player/usermanual-E283694-pdf
Oct 12, 2013 | RCA Lyra RD1072 MP3 Player
I need a rechargeable battery for my lenoxx cd player. The battery burned out.
They don't recommend rechargeable batteries.
Page 3...
15. The use of rechargeable batteries is not recommended for this set because their voltage and life is lower than standard batteries.
http://www.retrevo.com/support/Lenoxx-CD-102-Boomboxes-manual/id/22975ag216/t/2/
. For battery operation, use 6 size C batteries. We recommend alkaline batteries for longer life.
. When the batteries will not be used for a few weeks or more, remove them to avoid damage that can be caused
by battery leakage or corrosion.
Nov 04, 2010 | Lenoxx Electronics CD-102 Cassette/CD...
CD player won't operate on brand new batteries. It turns on for a moment then off in a couple seconds. Works with the car ac adapter. If there is no CD in it, it will say 'no disc' without turning off for...
I think you must have a good supply of current for the player and maybe you must try with rechargeable batteries. If this wont work the set has a fault in the power supply input regulator wherein the regulator must have a fault.You will need to remove the covers and use a multimeter- if you are familiar- to confirm this regulator. replace and proceed. Good day
Aug 10, 2010 | Panasonic SL-SX282C Personal CD Player
Replace rshargable batteries on opal
use rechargeable AAA cells if they fit.
Jan 24, 2010 | RCA OPAL M4001 MP3 Player
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
How can I charge my centon 4gb mp3 player?
I have the same player. You can use a rechargable battery. But you cannot charge the battery by connecting it to the USB. You must charge the battery with a AAA battery charger - they sell them at walmart for like $15. The rechargable battery really works excellent in this player - I listen to my player all day long and rechargeable batteries are the only way to go for me! Make sure you have four batteries though so you can always have a backup charged as the charger takes 8 hours to charge the batteries.
Jan 04, 2009 | Centon Electronics 001 MP3 Player
Replacing the rechargeable batteries
Contact you local Batteries Plus store. they seem to have just about everything! http://www.batteriesplus.com/
Sep 17, 2007 | Audiophase CDM450 Personal CD Player
424 people viewed this question
 Grubhead
Grubhead
