Frigidaire tumble action, quarter (coin) inadvertently went into drain and now there is a clanking noise when the washer is emptying . I think it is in the pump, but I am not sure how to open the pump to remove it.
  • Helen Hebb Jul 21, 2009
    Vic asked for the model number of my washer . The model number is GF1240AS
    President:
  • 1,136 Answers
Hi, If you will get me a model # so I can see the exact model you have. I will look it up and give you the instruction to get to the pump assembly.
Thanks
Vic
Posted on Jul 21, 2009
Pump making loud noise when draining water
Sometimes the coin trap needs to be emptied, coins and hard objects that fall out of pockets will end up there. Mine will make noises every year or so and I have to empty it. It's not difficult, you just have to lie on your back to get to it. Your manual should tell you where it is, if that is the problem. Good luck.
Apr 12, 2014 | Frigidaire Affinity ATF7000E Front Load...
It will not let the water out or spin I think it is the water pomp how do I change the pump I have a frigidaire tumble action washer
First try pressing the start and cancel buttons for about 3 seconds and see if there is an error code, then you can troubleshoot from there....Have you checked the drain lint trap? It is inside the accordian looking drain hose that attaches the drum to the pump. It may be clogged. Use a wet/dry shop vac to remove as much water as possible. Unplug the machine. then remove front panel and remove clamps to check if it is clogged. Hopefully that is the problem!
Mar 25, 2011 | Frigidaire 14 Cycle Tumble Action Washer
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Water Will not drain after cycle
The filter for the drain is located under the drum assembly. It is inside the rubber cover between the drum and the pump. It has 3 clamps that you will need to remove, than you can get at the filter inside the rubber housing. It will be clogged with coins, or lint from the wash, and once this is cleaned, the machine will work like new.
Joe the Plumber
Mid Hudson Heating & Plumbing
Woodstock, NY
Jan 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Tumble Action Washer
I called in an electrician/plumber - thanks !
Jul 01, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire Tumble Action Washer won't move to the next cycle
your pump is blocked or faulty a way to check is pull your washer out put your outlet hose to the ground placed either in a bucket or out the door if water comes out pump is faulty if it doesnt than its blocked were your outlet pipe goes into back panel is were your pump is make sure washer is switched off undo tip up undo clamp water will come floding out better of doing this outside if it comes out of pump than your pipe is blocked
Aug 13, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Washing Machines Logo
Top Washing Machines Experts
