Question about Dell 948 All-In-One InkJet Printer
My Dell Photo 924 won't feed regualr paper
My Dell Photo 924 won't feed regular paper anymore. Cardstock works just fine. I have read through lots of posts on this site and have tried shaking the printer upside down. I also tried feeding paper through backwards, but could not get it to go through. Throughout the process of trying to fix it, I found that,at first paper was pulling to the right and then jamming. Then, once I got cardstock to work (thorugh shaking, persistence prayer and whatever else I tried...), the paper started pulling to the left and then jamming. Now, cardstock works fine, but paper keeps pulling left and won't go through. Any idea how to get regular paper to work again? Thanks!
MsMitch
  • 41 Answers
SOURCE: paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Posted on May 28, 2008
map9966
  • 2351 Answers
SOURCE: Printing Business Cards on Cardstock
Yes, the roller system will only open wide enough for semi thick cardstock. If you read through you're manual you'll find the recommended card stock you can use. HP supports HP paper.
Here is a list of supported HP paper.
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=16118&lc=en&cc=us&dlc=en&dest_page=product
See the user manual on page 45.
Papers to avoid when printing
It would not hurt to remove the rear door & clean the rollers. (No soap). Dried soap film will cause paper to stick to the rollers. You can go to Wallmart or a local hardware store & buy a bottle of Grease Lighting. This heavy duty cleaner (When dry), does not leave any soap film. Great for cleaning just about anything.
If you wish to download the user manual from HP (It's easer to see & find information faster. Just click on this link:
http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
Good Luck!
Mike
Posted on Jun 13, 2008
Ajkill
  • 2035 Answers
SOURCE: brother laser printer wont print
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Posted on Feb 09, 2009
  • 220 Answers
SOURCE: Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Posted on Jun 26, 2009
  • 20 Answers
SOURCE: My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Posted on Sep 06, 2009
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
I have a dell photo printer 926 that will not let the paper feed. no amount of pushing or trying the rollers will not take the paper.
plz check the printer paper roller if it is ok or not , if it is ok then after that uninstall the printer driver and then reinstall the printer driver again
May 27, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 Photo Printer will not recognize that paper is loaded
you will likely have to take this in for (hopefully free!) warranty service. it sounds like there was an assembly issue here. good luck!
Feb 17, 2009 | Dell 924 All-in-One InkJet Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Paper does not feed
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Feb 08, 2009 | Dell 924 All-in-One InkJet Printer
How to get my Dell Photo 924 to feed paper for printing?
if you are having issue with the paper feed ,moz-screenshot.jpg try these steps
1. Unplug the power adapter
2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
3.turn the printer upside down and gently tab on the base,.
4. Put your Hand inside the Input paper tray and manually roll the two rollers
5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
Try all these steps and if you still have the paper feed issue then purchase the new printer
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Paper won't feed
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
Paper feed problem.
ATN master 3202 clean paper feed rollers with a micrfiber cloth moistened with rubbing alcohol will be rollers that pull paper probably just need wiping off after a lot of use these rollers build up paper dust that causes traction problems
Nov 01, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
Dell 948 All-In-One InkJet Printer Logo
201 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
