Question about Car Audio & Video
P0335 CKP SENSOR P0420 CATALYST EFFIENCY LOW P1629THEFT FUEL ENABLE
  • 11,896 Answers
What type of vehicle is this? I then can tell you what the codes mean and how to fix it.
Posted on Jul 27, 2009
What is the code p0335 on 2012 chevy sonic
Follow the link for info on this OBD2 fault code. https://www.obd-codes.com/p0335
Dec 10, 2016 | Cars & Trucks
What means catalyst Efficiency below normal
      Got it scanned and it's P0420: Catalyst efficiency below thresholdbank 1. They said it could be a bad catalytic converter or oxygen sensor. I borrowed a scanner and tried to measure the oxygen sensor readings over time.Sep 8, 2011
      civic - Check Engine code P0420 Catalyst efficiency below ...
      mechanics.stackexchange.com/.../check-engine-code-p0420-catalyst-efficie...
    Feedback
    P0420 Error Code: Catalyst System Efficiency Below ...
    www.obd-codes.com/p0420
    P0420 OBD-II Trouble Code. Technical Description. Catalyst System Efficiency Below Threshold (Bank 1). What does that mean? This diagnostic trouble code ...
    P0420 Code Fix How Its Done Catalyst Efficiency Below ...
    ? 4:25
    https://www.youtube.com/watch?v=-c8090n1Ihs
    Jun 20, 2014 - Uploaded by ACE AUTOS UK
    Here is a tutorial on P0420 code fix catalyst efficiency below threshold How To Diagnose a p0420 code ...
Jan 26, 2016 | Cars & Trucks
I am getting the following codes on my 2002 Nissan Altima v6 3.5 liter P1430, P1420, P1805, P1152, P1102, P1011, P1021 & P1335 I'm going crazy here. Please help!
Definition of Diagnostic Trouble Code P1430 Ford: Electric Air Pump Secondary Lincoln: Electric Air Pump Secondary Mazda: Electric Air Pump Secondary Mercury: Electric Air Pump Secondary Toyota: Intake Constrictor CTRL Circuit Open or Short
Definition of Diagnostic Trouble Code P1420 Audi: Second Air Injection Valve Circ Electrical Malfunction BMW: Secondary Air Valve Control Circuit Electrical Buick: Intake Air Low Pressure Switch Circuit Low Voltage Cadillac: Intake Air Low Pressure Switch Circuit Low Voltage Chevrolet: Intake Air Low Pressure Switch Circuit Low Voltage Chrysler: Register Resonant Charging 1 (RRC1) Dodge: Register Resonant Charging 1 (RRC1) Ford: Catalyst Temperature Sensor GMC: Intake Air Low Pressure Switch Circuit Low Voltage Honda: Nox Adsorptive Catalyst System Efficiency Below Threshold Catalytic converter Jeep: Register Resonant Charging 1 (RRC1) Lincoln: Catalyst Temperature Sensor Mazda: Catalyst system efficiency below threshold (bank 1) Mercedes: AIR Pump Switch over Valve Mercury: Catalyst Temperature Sensor Oldsmobile: Intake Air Low Pressure Switch Circuit Low Voltage Pontiac: Intake Air Low Pressure Switch Circuit Low Voltage Saturn: Intake Air Low Pressure Switch Circuit Low Voltage Subaru: EVAP Purge Control Solenoid Circuit High Input Toyota: SCV Control Circuit Malfunction Volkswagen: Second Air Injection Valve Circ Electrical Malfunction
Definition of Diagnostic Trouble Code P1805 Ford: Four wheel drive high indicator circuit failure Lincoln: Four wheel drive high indicator circuit failure Mazda: (4WD) High Indicator Open Circuit Mercury: Four wheel drive high indicator circuit failure Toyota: SB Solenoid Circuit Malfunction
Definition of Diagnostic Trouble Code P1152 Audi: Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded BMW: Oxygen Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1) Ford: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Jaguar: Lack of H02S-21 switch, sensor indicates rich Land Rover: Oxygen sensor response time bank 2.Short circuit to ground Lincoln: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Mazda: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Mercury: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Subaru: Oxygen sensor range /performance problem (Low) Volkswagen: Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded Volvo: Oxygen Sensor Front, Bank 2
Definition of Diagnostic Trouble Code P1102 Acura: Mass Airflow (MAF) Sensor Lower Than Expected Comprehensive Audi: Oxygen Sensor Heating Circuit,Bank1-Sensor1 Short to B+ Chrysler: HEV Stop Request Performance Dodge: HEV Stop Request Performance Hyundai: MAP Sensor Circuit Low Input Jeep: HEV Stop Request Performance Kia: Heated Oxygen Sensor Bank 1 Sensor 1 Heater Circuit High Input Land Rover: Throttle to air flow plausibility not active.Last occurrence - minimum signal Mazda: Mass Air Flow Sensor In Range But Lower Than Expected Mitsubishi: Traction Control Ventilation Solenoid Circuit Porsche: Heated Oxygen Sensor 1 Ahead Of TWC Heater Short To B+ Saab: Front Heated Oxygen Sensor Bank 1, Control Module Input, Current in Pre-Heating Circuit Too High Subaru: Pressure Sources Switching Solenoid Valve Circuit Malfunction Volkswagen: Oxygen Sensor Heating Circuit,Bank1-Sensor1 Short to B+ Volvo: Power Stage Group B
Definition of Diagnostic Trouble Code P1011 Saab: Injector Cylinder 1 Shorting To Ground Toyota: OCV for VVTL Open Malfunction (Bank 1)
Definition of Diagnostic Trouble Code P1021 Honda: Valve Pause System Stuck On Comprehensive Mitsubishi: OCV OPN. Bank 1 Saab: Injector Cylinder 2 Shorting To Ground Toyota: OCV for VVTL Open Malfunction (Bank 2)
Definition of Diagnostic Trouble Code P1335 Audi: Engine Torque Monitoring 2 Control Limit Exceeded Buick: CKP Circuit Cadillac: CKP Circuit Chevrolet: CKP Circuit Ford: (EGR) Position Sensor Minimum Stop Performance GMC: CKP Circuit Infiniti: CKP Sensor (Ref) Jaguar: CKPS Circuit Malfunction Land Rover: Exhaust gas recirculation position sensor minimum stop performance. Lexus: Igniter Circuit Malfunction Bank 2 (During Engine Running) Lincoln: (EGR) Position Sensor Minimum Stop Performance Mazda: (EGR) Position Sensor Minimum Stop Performance Mercedes: CKP Sensor Circuit Malfunction, Bank 2 Mercury: (EGR) Position Sensor Minimum Stop Performance Oldsmobile: CKP Circuit Pontiac: CKP Circuit Saturn: CKP Circuit Toyota: No CKP Sensor Signal Engine Running Volkswagen: Engine Torque Monitoring 2 Control Limit Exceeded http://www.obd-codes.com/trouble_codes/nissan
Jun 29, 2015 | Nissan Cars & Trucks
I have OBD codes
P1168 Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL Low Voltage
P0420 Catalyst System Efficiency Below Threshold.
P1615 Malfunction of communication with driver MPCS unit.
Dec 30, 2013 | Rolling Code Scrambler
Dodge caravan 07 3.3L V6 have trouble code P0420
Generally speaking the catalytic converter is worn out and the system reads this and sets the code P0420
Nov 01, 2012 | Dodge Cars & Trucks
Check engine light is on in my 2005 altima 2.5 got it scanned and the codes i got were P0335 /P0725/P0420 also car keeps stalling
po335 and 725 bad crank sensor and this is also reason for stalling.po 420 catalyst has lost efficiency....needs new catalytic converter ...covered under 8year 80000 mile emmisions warranty.
Feb 08, 2011 | 2005 Nissan Altima
Check engine light on, code reads p0420
Hi and welcome to FixYa!
Code p0420 means Catalyst System Efficiency Below Threshold (Bank 1). This will surely needs attention to resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 26, 2011 | 1999 Buick Century
Check engine light is on, Code says P0420 catalyst effiency
So whats it doing is the rear sensor is not reading the correct information ,so test the rear O2 sensor or all of them is better with a automotive meter and find a garage that has an exhaust analyser then put the probe up the tailpipe and see what the emmisions are like
Jan 24, 2011 | Chevrolet Monte Carlo Cars & Trucks
Check engine light on got a diognostic and code P0128, P0420, and P0455 popped up trying to figure out what these codes mean and what I need to fix on my car
P0128 ECT Sensor Below Thermostat Regulating Temperature
P0420 Catalyst System Bank 1 Low Efficiency
P0455 EVAP System Large Leak (0.080") Detected
For the 'P0128' your engine isn't getting up to operating temerature. This could be because of a low coolant level or your thermostat is stuck open. For 'P0420', this indicates your catalyst isn't working as well as it should. If you have a four cylinder, this will be the first cat in the system, if you have a V6, then it will be the one on the driver side. Since this code can also indicate a clogged catalyst, you should get this checked at an exhaust shop. They can do a back pressure test to see if it is clogged. For the 'P0455', this indicates you have a fuel leak from the pressure system in the fuel tank. The EVAP takes fuel from the tank that builds up pressure and stores it in a canister until you start the engine. Then it shunts this fuel into the engine to be burned.
Jan 06, 2011 | 2005 Pontiac Grand Prix
Vsc and check engine light is on . Had it read and code p0420 came up. Autozone said it could be an air leak in exhaust, AF sensor error, fuel system fault or faulty catalytic converter. Is there a cheap...
DTC P0420: Catalyst System Efficiency Below Threashold (Bank 1)
The ECM uses sensors mounted before and after the three-way catalyst (TWC) to monitor its efficiency. The first sensor, and Air Fuel ratio (A/F) sensor, sends pre-catalyst A/F ratio information to the ECM. The second sensor, a heated oxygen sensor (O2S), sends post-catalyst information to the ECM. The ECM compares these two signals to judge the efficiency of the catalyst and the catalyst's ability to store oxygen. During normal operation, the TWC stores and releases oxygen as needed. The capacity to store oxygen results in a low variation in the post-TWC exhaust stream as shown below.
If the catalyst is functioning normally, the waveform of the heated oxygen sensor slowly switches between RICH and LEAN. If the catalyst is deteriorated, the waveform will alternate frequently between RICH and LEAN. As the catalyst efficiency degrades, its ability to store oxygen is reduced and the catalyst output becomes more variable. When running the monitor, the ECM compares sensor 1 signals (A/F sensor) over a specific amount of time to determine catalyst efficiency. The ECM begins by calculating the signal length for both sensors (for the rear oxygen sensor, the ECM uses the output voltage signal length). If the oxygen sensor output voltage signal length is greater than the threshold (threshold is calculated based on the A/F sensor signal length), the ECM concludes that the catalyst is malfunctioning. The ECM will turn on the MIL and a DTC will be set.
Hope this helps :)
Oct 19, 2009 | 2005 Toyota Highlander
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
