Cars & Trucks Logo
t
trevor Wilson Posted on Jan 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2006 Polaris MSX 140 jet ski and it has been sitting unused for nearly 3 years the Forward/Neutral/Reverse lever is jammed, how do I loosen it?
Bill Boyd
Level 3:
Top Expert:
  • Cars & Trucks Master 53,816 Answers
  • Posted on Jan 10, 2017
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11945686
Points
172802
If there is a cable on the end of the lever , replace the cable assembly
if the lever is direct connection, spray with an anti rust penetrant on a regular basis for a few days then try to move it
try using localized heat from a butane torch to break the rust / corrosion seal while trying to move it
Testimonial: "Ok, thanks Bill, i will take the cover off and see how it goes."
  • 3 more comments
  • trevor Wilson
    trevor Wilson Jan 10, 2017
    Also, there is a lot of white smoke when the engine is revved, could this be because of some old oil that is still in there?
  • Bill Boyd Jan 10, 2017
    blue smoke is oil, white smoke is water in the oil or fuel
  • trevor Wilson
    Ok, will it be safe to run it through until it runs out?
    Impossible to say as the water could be from a corrosion hole
    3 years is a long time for a unit that operated in the water environment but was left high and dry
  • trevor Wilson
    Ok, thanks for your help Bill
My06 jeep commander is stuck in neutral
USA CAR, LHD , LEFT HAND DRIVE CAR NOT OUR EXPORT.
A/T BOX.
STUCK IN PARK MEANS THE LEVER DOES NOT MOVE
no you mean, PRNDL, R D and L are all dead,
but the shifter does no jam up ever.
GRINDS, NO GOOD A/T BOX GRINDS EVER.
I HAVE JEEP MANUALS, MOST.
1ST YEAR COMMANDER, AND IS near same as grand Cherokee in regards to the trans mission, but 2 kids are used.
no VIN posted so I can'T know what is under the hood and behind THE ENGine.
3.7L or 4.7L??? GAS ENGINE or the Diesel>??
2wd or 4wd.
NAG1 OR 454RFE.
DIY
check all fuse first
then scan the cars DLC OBD2 port (16p) for errors called DLC
codes,
if it tells you shift solenoids are bad, then you know what to do next
or the cables under the shift lever box to transmission are rusted and snapped off.
the shift lever must go to DRIVE then below on the actual side of the transmission, the lever there must go to the detent DRIVE
or it fails hard.
quote
The floor shifter lever and gate positions should be in alignment with all transmission PARK, NEUTRAL, and gear detent positions.
2013 Honda Rubicon TRX500FA, Starting in Gear / Neutral Positions
When starting in gear there is a switch , controlled by the front brake lever to avoid over revving, make sure the front brake lever is fully applied when starting in gear , if the engine starts to run rough disengage the brake lever fully, if rough running continues then likely switch needs replacing/servicing
Nov 07, 2021 • ATVs
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Automatic transmission will not engage gear
Sounds like the transmission is gone .Check the fluid level ,and sometimes the filters inside the transmission gets clogged up.have it checked by a qualified transmission mechanic.
1991 Ford F150 won't shift into park or reverse. Will go into neutral and drive, and the linkage at the transmission moves ok
The linkage may be out of adjustment preventing the shifter from moving into reverse or park.
One way to test this is to disconnect the linkage and manually move the lever on the transmision making sure that it can be set into park. Also try moving the lever counting each click from park to low gear to make sure it is clicking into each gear. If this works then the linkage is probably out of adjustment.
On the link cable there is typically a bolt in an oval shaped metal near the transmission shift lever.
1)Detach the shift cable from the transmission shift lever
2)Put the transmision shift lever in the park position, and also the shifter in the cab
3)Loosen the adjustment bolt
4)Reattach the cable to the lever
5)Tighten the adjustment bolt in place
6)Confirm that you can shift through all of the gears
Hope this helps
Transmission trouble
Vehicle does not move forward.
The following parts and assemblies need to be checked thoroughly.
1. Manual valve
2. Valve body assembly
3. Forward clutch C1
4. Planetary gear unit
5. 1st and reverse brake (B3)
6. Park/ neutral position switch
2helpful
1971 ford f100 pickup neutral safety switch wiring color code
Ford Neutral Safety Switch; Ford Reverse Light Switch; Backup Light Switch.
The Neutral Safety Switch wires in my 1971 Ford F100 are orange with a blue stripe.
The Reverse, or Backup Light Switch wires are black with a red stripe.
There are two sets of two wires across this combined neutral safety and backup light switch, for a total of 4 wires. Photos are at the end of this post.
The switch for the 1971 Ford F100 pickup truck is the same as in many other years and models. For details, including parts numbers, see the following quote from an expert at Ford Truck Enthusiasts:
http://www.ford-trucks.com/forums/287185-back-up-light-and-neutral-safety-switch-2.html#post5601846
The neutral switch also controls the backup lights, and is the same 1967/77.
C7TZ-7A247-A .. Neutral/Backup Switch (Motorcraft SW-600)
There is no separate backup light switch..except on 1967/68 F350's.
Neutral switch location 1967/77:
The plastic half moon shaped neutral safety switch mounts on the outside lower portion of the steering column (NOT on the transmission!).
It's activated by an inverted Y shaped lever that snaps on the shift tube
D0TZ-7B097-B .. Lever, Neutral Switch Actuator = From FTE sponsor DIRECT FORD PARTS: Ford suggested retail price: $18.72 / FTE member net: $13.23.
The switch is also still available from Ford, but the website is down so I can't post the list & net prices. .
1978 is the FIRST year the F100/350's have the neutral switch mounted on the transmission. __________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
IMAGES
Driver side of the neutral / reverse switch showing the travel slot for the switch arm, the return tensioning spring, and the arm.
The front, steering wheel side of the neutral / reverse switch after removal from the steering column. The switch's two functions are actuated when the lever in the column moves the switch lever shown here to different positions as gears are selected.
The neutral switch is installed on the steering column near the firewall, with 5/8" bolts into the steering column (visible hole) and down column from a rectangular opening in the column housing. The actuating lever for the switch is attached to the gear shift shaft inside the housing; the lever is visibly protruding from the opening in this image.
Back of neutral / reverse switch, showing the wiring attachments. Black with red stripe is the backup light wiring, Orange with blue stripe is the neutral safety switch, it prevents starting in gears other than neutral & park.
1helpful
3.3 voyager, would not go into reverse went forward a ok, now will go into reverse but wont go forward
With a partner and engine off but key in on (not start) position: Have them shift from Park to Low one gear at a time, while you watch the shift linkage located on top of the transmission. Sounds like the shift cable is loose. IF SO: Place Shift Lever in Park. Loosen the the cable adjustment screw. Move the shift rod (going into the transmission) towards the front of the vehicle until in Park. Tighten the cable adjustment screw to 100 in-lbs. Check Park/Neutral starting only.
Transmission is stuck in reverse but the shifter is in neutral and will not go in gear
Check for wear in the gear lever selector/gate mechanism.
It may have allowed the lever to select reverse, the 'jump' the lockout gate back to neutral position for selection of forward gears.
You may be able to de-select reverse if you access the lever directly at the gearbox case.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
