1. Air gap / Drain hoses If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer Replace if defective (note: uncommon problem).
i have bosch excell dishwasher. it was working fine. we were away for 2 months.now came back-tried...
(More)
i have bosch excell dishwasher. it was working fine. we were away for 2 months.now came back-tried to use the dishwasher. it doesnt start any washing cycle. only gives a sound as if the water is draing every few seconds ,and on opening the dishwasher there is always some water on the floor of the dishwasher. can you kindly help
my frigidare dish washer is not located right next to the sink and it doesnt aiways pump all the...
(More)
my frigidare dish washer is not located right next to the sink and it doesnt aiways pump all the water out.is there a replacement pump with more power.
bosch exxcel slimline dishwasher starts cycle then stops after a few minutes still full of water...
(More)
bosch exxcel slimline dishwasher starts cycle then stops after a few minutes still full of water then keeps stopping and starting cycle can take up to 2 hours to complete . will start again if i empty water out of machine, checked hose and they're not blocked
