Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
Blue shaped dome with 3 spikes on top right hand side of phone
Comes on after the memory card comes on
  • mconnarty Jul 21, 2009
    Thanks for your answer, this has been annoying me for some time. Your help is much appreciated.
  • mconnarty Jul 22, 2009
    Hi
    Unfortunatly this did not work, i saved all my files from my memory card and formatted but nothing happened. Do you have any other suggestions, that would be great. Thanks
    President:
  • Samsung Master
  • 688 Answers
You may need to format your memory card to work in your phone.
go to your settings and sd card and format the card.
if you have something on it you want to save, save it on the computer prior to the format or it will be lost.
Posted on Jul 21, 2009
BLUE LIGHT BLINK 5TIME TV WILL NOT COME ON MAKE NOSIE FROM BACK OF TV
Hi A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed. This will cure the problem as they overheat being sat next to a heatsink that gets very hot! Try and change them for the same 3300uf but a higher voltage. Hope this helps
Aug 08, 2011 | RCA Televison & Video
I cant move any files from phone memory to memory card because it is write protected?how to solve this problem?
First you have to remove ur Memory Card from ur phone, in ur Memory Card (with adapter, which is attached with ur card) there is one button u would see in right hand side...
So u have to move that button to another side and then insert ur Memory Card, then the files will be moving from ur Memory Card to ur phone memory.. Thatssssssss ittttt._227.jpg
Dec 03, 2010 | Motorola Mobility ROKR E6 Smartphone
How do i remove the memory card of the phone n81??
On right hand side and you will get a panel. You can press the panel and memory card will come out
May 10, 2010 | Nokia N81 Smartphone
WHAT IS THE SMALL BLUE LIGHT FOR ON TOP RIGHT HAND ON A MITSUBISH
The blue light is usually for the high beam headlight indicator. If you feel this is not accurate, please describe its shape and I'll see if I can decipher it.
Mar 29, 2010 | 1998 Mitsubishi Galant
Need to know what color wires run my mass air flow sensor in my 93 maxda mx3 1.8l should be 2 wires what color and where to find then
You can pick up a Haynes manual. They have all necessary diagrams in them, including electrical schematics.
Regards,
matt
Sep 15, 2009 | 1993 Mazda MX-3
Memory Card not detected !!!
back cover has a peg or spike that push down one pin on the right of the camera lens, if your back cover is not properly closed, warped or you have something (such as a spare simcard) wedged inside, the memory card will not be detected. To save the hassle to get a new cover, wedge something tiny on that pin before putting back your back cover. If this does not solve your problem, better send your phone to a service center.
Jul 06, 2009 | Nokia 6300 Cellular Phone
Cant down load
hello there...that's right you can get a usb data cable, blue tooth ,or memory card reader to transfer you pictures to your computer....
you can directly print the picture as some of the printers come with card readers built in which is very convinient
consider visiting a mobile accessory shop you will have all the options there
my best pick will be memory card reader if you already have a printer...it is very cheap...and can read multiple cards...so in future if you change your mobile you will not have any problem
like with usb cable (different for different phone)
blue tooth and getting a new printer is a costly affair...blue tooth often have connectivity and software issues
go for memory card reader ...cheap ,reliable ,fast and best of all
Hope this helps
Cheers
May 25, 2009 | Motorola Mobility RAZR V3
Blue screen Bootloader usb init I was charging my phone and when I went to use it I couldnt the screen was blue with the Motorola symble and it read Bootloader usb init I have tryed removing the battery...
take out the battery and sim card and youwill see a metal bended thing beside of the sim card insert placing not on it on the right hand top press it down or bend it and your phone will reset your memory of your phone will not be erased
Apr 12, 2008 | Motorola Mobility RAZR V3
Help with memory
Make sure that when you go to My Stuff, you select the correct memory source. The internal memory is located on the upper left hand side and the memory card is on the upper right hand side. By default the phone shows the internal memory, so you have to select the memory card every time you want to access it.
Dec 29, 2007 | LG Prada KE850 Cellular Phone
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
57 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
