Question about Psi Blue Max 2200 High Pressure Gas Power Washer
Were can i fine parts for a blue max perrure washer .call me back at 229 759 6659. thanks
Homier makes the blue max pressure washer. The # for the warehouse is 260-356-9477.
Posted on Apr 24, 2010
Need a replacement hose for the Blue Max pw2200/03435 power washer (2200 psi)
Check jackssmallenginerepair.com or ereplacementparts.com they should have what you need.
Jul 25, 2011 | Psi Blue Max 2200 High Pressure Gas Power...
Need the connection for the wand hose to the pump for Blue Max Gasoline High Presssure Washer stock No: PW2200/03435
Your pressure washer is sold under various brand names, however I believe that it is made by campbell hausfeld. Parts are here:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/campbell-hausfeld/PW2200
Take a close look at the pump diagram to make sure it looks like yours. Good luck
Nov 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
I am looking for a replacement hose for my Blue Max pw2200/03435. Does one exist? If so, where can I get one?
Here is a site that shows the lightweight blue max power washer hose
http://www.shopping.com/Psi-Blue-Max-2200-Psi-High-Pressure-Gas-Power-Washer/products
It looks to be a right-fine chinese product manufactured using the technology we paid-for and developed over the past 50 years and then gave away with our jobs overseas.
If you bump up to professional power washers..
Power washer hoses are interchangeable as long as the quick-connects on end of hose can unscrew.
We used power washers a couple times a week. When I needed a new hose, I went to the hydraulic hose shop. They make steel-wound hydraulic hoses for tractors and heavy equipment.
Search 'hydraulic hose in Your-town-your-state'
If the quick-connect ends of the Blue max hose do not come off, check the quick-connect end attached to machine. If it comes off, you can buy a new gun and hose. If the quick connect on the blue max machine does not come off, then the life of your machine is directly related to the life of that single quick-connect fitting.
Search 'power washer guns'
Here's a site with guns like we used
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 15, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
What Spark Plug do I use for my Blue Max 2200 Power Washer.
Spark plugs: BPR6ES (NGK), W20EPR-U (DENSO). You cna cross ref any other equivalent with a spark plug cross ref book.
Thanks for choosing Fixya.
Kelly
Aug 12, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Can't find replacement recoil kit
What engine is on your presure washer? I really need a model number to give you the correct information.
If you have the engine model number you can look the engine up on the net at:
http://jackssmallengines.com/help.cfm
and find your recoil assy.
If it is just the rope that broke you can take the recoil to any lawn mower repair shop and they will repair your recoil by replacing the needed parts or replace the rope. You do not need to take the whole unit to the lawn mower repair shop. FYI a NEW honda recoil assy ranges from $32.00 - $68.00 depending on net source.
Thanks for using FixYa.
Kelly
Apr 16, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Kelly
Apr 05, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Need parts for Wand
yes go to Northern Tool supply Lowe's or HomeDepo any of these places should hace what you are looking for
Feb 02, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
382 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
