Question about Kenmore 63942 Dryer
Kenmore 90 series propane gas dryer
My propane had to run out to change fittings on my tank. Now I don't know how to relight or reignite my pilot light on my dryer. I can remove the front panel but then what?
    President:
  • 1,136 Answers
Hi, You should not have a pilot light, There are electronic ignitors on the dryers. Unless this dryer is 40 years old, just start the dryer and the heat should come on.
If the heat does not work, there must be another issue.
Please let me know if I can help you further.
Thanks
Vic
Posted on Jul 21, 2009
Kenmore 90 series gas dryer no heat
The gas ignitor most likley is not functioning. They do not have a pilot light like appliances in the oold days. They must ignite a new flame each use. if you don't smell gas when you try and use, then it is the ignitor and the computerized sensor tells the gas not to turn on because the initial flame has not been created.
Oct 08, 2012 | Kenmore 63942 Dryer
Any time you run out of lp gas in a tank fed lp gas appliance what is the proper way to reignite the appliance when the gas lines have air in them?
Depends on the appliance. If it's a gas grill, turn the tank on very, very slowly until it's fully open.
If it's a gas heater or gas log set, the air will have to be purged out of the line, so the gas can reach the pilot, before relighting. If it's a gas range, depending on how long a run of piping, you may also need to purge it. If it's a gas furnace, you'll have to do the same thing. Unless, it's a high efficiency gas furnace, then it will purge itself when it runs thru the start up cycle.
Hope this helps.
Rich
Feb 09, 2011 | Thermos Stainless Steel Gas Grill
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
I have a kenmore 80 series gas dryer and the gas line to it was recently turned off temporarily and now it won't get gas to heat up now that it is back on. Is there something wrong w/ the pilot mechanism??...
When gas is shut off, even for a short period of time, air enters the gas line and must be purged before the pilot will light.
Hold down the pilot light button longer than you think you should have to, then wait about five minutes to clear any gas that might have escaped then try again to relight the pilot. You may need to do this two or three times in five minute intervals.
Hope this was helpful.
Oct 10, 2009 | Kenmore 73952 Gas Dryer
Ran out of gas, how to restart dryer
All new dryers come with electronic ignition sources.
There is no pilot light to be lite on this type of gas dryer.
Feb 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
How to light the pilot for gas dryer, 90 plus series
Dryers haven't used pilot lights in over 30 years. You have an electronic igniter
Jan 16, 2018 | Kenmore 74602 Gas Dryer
Whrilpool gas dryer
Let it run. If nothing has changed, the dryer will go through several relight cycles and should eventually purge the lines of air.
Jan 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Kenmore 63942 Dryer Logo
194 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
