ok i am computer stupid lol how do i reboot my os? and i have ran scans and it fixes them but it sitll is showing dll errors thank you for takening the time to help meok i am computer stupid lol how do i reboot my os? and i have ran scans and it fixes them but it sitll is showing dll errors thank you for takening the time to help me
You can't post conmments that contain an email address.
ANY Yahoo! Messenger program will not install properly if a former program, or an incomplete install, has not been completely deleted from the computer first. (Don't worry - your Contacts List will be saved into the fresh installation of an updated Messenger!) Delete all Yahoo Messenger references from the registry.
Use the Control Panel > Add/Remove Programs method,
Then double-check by going to Start > Search > files and folders > Yahoo! Messenger (notice the exclamation mark in the title).
Write down and delete all references manually if necessary. The uninstaller works well for Vista and Win 7, but not for XP - it leaves behind MANY junk files when uninstalling.
If you are using Internet Explorer 8 or 9 as your browser, Yahoo Messenger 10 will not work properly without Flash and Java programs installed, and possibly the .NET framework update. (Messenger 11 is still in beta format, so be wary of using it yet.). you'll have to download Flash and Java programs as well.
Last, you could used this link to fix a dll error: http://fix-all-dll-errors.com/d3d9.dll/ Just click on the link, then click the button "Fix dll errors now." This should fix the issue. Hope this helps. Thank you for using FixYa!
go to www.yahoo.com and find the download for yahoo messenger, download it and install on your computer, it should override the install you now have and fix the dll issure.
Looks like your missing a .dll file. The error should tell you which .dll file your missing. You can do a Google search to find the .dll and where to put it.
Just go into the installation path of Yahoo Messenger
> C:\Program files\Yahoo!\Messenger
and there should be a couple of .reg files
> default.reg and intl.reg
I merged those files (with a double click) and now Messenger works even on my limited account.
I think some yahoo messenger files are corrupted from your program files so you need to Re-install the yahoo messenger Just install the new version of the messenger http://messenger.yahoo.com/download/
I have the same problem with this error and I have uninstalled and reinstalled a dozen or so times. Plus I have even tried to run a registry cleaner as well and a virus scan and I still come up with the same problem. What do I do to solve this problem??
The error message indicates your operating system is not able to load one of the files required for Yahoo messenger to work.
To make sure Yahoo messenger is installed properly, download the installation files and save them to your desktop.
Once you have the installation file...
Open the control panel and uninstall the existing version of Yahoo messenger. This will remove the program from your computer and clear out the registry entries that were created during the first install of Yahoo messenger.
Reboot your pc and then run the Yahoo messenger installation file you downloaded to your desktop.
The system reboot is a precautionary measure to ensure that none of the files used by Yahoo messenger are loaded into memory during the reinstall.
