After inputting my log in password,computer takes me to my wallpaper and shows no icons, 5seconds later it goes to logging off and i have to put in my log in password then the same thing happens again, can i fix this without taking the computer back to basics
  • 453 Answers
You may not be able to log on to system using either Normal Mode or Safe Mode. This occur only when Winlogon service tries to load the Windows default shell (explorer.exe) and user shell (userinit.exe) from registry. This service searches for Explorer.exe and Userinit.exe in the following path of registry:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Edit these values and type the correct path of shell :
Shell = explorer.exe
Userinit=X:\windows\system32\userinit.exe
NOTE: These files may also be deleted by spywares. You may need to extract them using Windows CD.
Steps for rectifying this problem:
Log on to a networked computer.
Run Regedit.exe
Point your cursor to HKEY_LOCAL_MACHINE
Select File > Connect Remote Registry
Type computer name (infected computer)
Navigate to the following location in registry of destination or infected computer
Edit these two values in right pane:
Shell
Userinit
Change these two values to
Shell=explorer.exe
Userinit = x:\windows\system32\userinit.exe
Exit from Registry
Restart Infected computer.
You should be able to log on to computer
Posted on Jul 21, 2009
  • Sai Kiran Camsarapalli Jul 21, 2009
    If this does not work then probably try using a different user / administrator.
    If it works then try to install an anti spyware to get rid of the spyware.
    If this does not work kindly comment then the only solution would be to go for a complete system reinstall or a complete PC restore.
Windows 10 is stuck on login page then goes blank and goes right back to login page
Run a check disk on your hard drive.
Run and SFC scan on your computer.
Repair your profile.
Sep 11, 2017 | The Computers & Internet
How can change user name and password in router D-Link?
Reading this question, I'm thinking that you want to change the SSID, this is the name that shows up when searching for wireless connection. First, you must find out what is your gateway, this is the main IP address. It usually is 192.168.0.1 or 192.168.1.1. Once you have that information, you need to log in the router, to log in, open a browser and type the gateway (Ex. http://192.168.0.1) A new window will pop up asking for a log in information. The most common default log in info are:
Username Password
admin admin
root 1234
admin password
Once you had successfully log in, take a look at what you have in front of you. There must be a tab name Wireless, click it. Look for SSID and change it to what you want to name it. Security should be in the same path, if not, save your work and log in again, but since you already change the SSID, you must search for the wireless connection again, and input the password, log in again.
If security is within wireless, then just head over to password and change it. You can also change the encryption type, I recommend WPA 2 personal. Once everything is all set up with the new SSID and the new password, click Save.
Search for the new SSID or router with your computer and input your new password once found by the computer./ Good luck.
May 31, 2015 | Computers & Internet
I am trying to get into my facebook from another computer and I can't seem to log in. Is there a screen somewhere, where I can enter my name and password to take me to my home. it just keeps going back...
You will first need to log out of the other person's account. Just click the small gear icon in the top right and click log out. Once you log out you can then enter your email and password to log in.
Just don't forget to log out of your account once your finished or others will be able to access your account on that computer.
Hope that helps!
Sep 16, 2013 | Computers & Internet
When I log on it goes to the window screen and freezes up
Restart your computer, as it's restarting press f8 a boot up menu should pop up, among the options in that menu you'll see last known good configuration, select it, you're computer should hopefully start up normally, if it does not you may need to reformat, or take it into a tech shop for assistance.
Feb 13, 2013 | Dell Inspiron 8500 Notebook
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Jul 06, 2012 | Dell OptiPlex GX260 PC Desktop
Logs on ok then shows no icons and goes straight to logging off
Got any enemies? :)
This is a long shot but i used to play this prank on people in college.
Put a logoff or shutdown shortcut in their startup folder. As soon as the PC starts up, it immediately shuts down or logs off.
I think safe mode is the best way to fix that, but again that is probably not the problem.
Jul 21, 2009 | Computers & Internet
Will not save
Are you logging in as a different user ? Goto START then CONTROL PANEL then USER ACCOUNTS. If you are the only user of the computer, then you can delete all users except administrator. You then can reboot and windows should log you in as admin only. Just make sure you have the proper password. Please note that you can only delete use accounts if you have that privilege. If you don't then you need to goto START, then LOG OFF. Then you can log in a admin but again, you need the admin password.
Mar 20, 2009 | Dell Computers & Internet
Vostro 1500 DELL won't start
If you have almost given up all hope, you might want to try doing what I tried: Please search this topic here at fixya:
Dell Vostro 1000 won't turn on/no power at allI hope it helps, Rod
Feb 23, 2009 | Dell Vostro 1500 Notebook
Not shutting down
sounds like that when you did a restore one of the files did not load correctly try using your repair disk and that should fix it
Feb 10, 2009 | Medion M3 Composer 5200 PC Desktop
Computers & Internet Logo
David Payne
David Payne
