Rv roof top ac blows cold but very hard out of the vents i cleaned the coils with no help.the air is cool that comes out,but with no force.what can i do?
  • Mike Butler
    Mike Butler May 11, 2010
    Always been that way?
  • 534 Answers
Sounds as if your blower motor in high speed has the windings going out. You need to check to see what the amps the motor is pulling to see if the blower motor is going out. It is also possible theat you may just need a blower motor capacitor. To check the amps you need an amp meter and taking the black wire coming from the motor and place the amp clip around this wire and start the a/c this will give you the amp pull and compare this with the amps the motor is specified for. If the amp being pulled is higher than what the motor is designed for then the motor is going out and not giving you the proper rpms in order for the unit to operate effeciently. Also to check for the capacitor you'll need a capacitor meter and follow the instructions. I would check the capacitor first before the motor in the event the capacitor is bad it will not all the motor to achieve the proper rpms.. Also it is easier to change out than a motor. Good Luck
Dave
Posted on Jul 22, 2009
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
Runs/cools great unless outside temp gets in high 80s
try replacing capacitors. or communication cable issue to that a/c
Jun 25, 2013 | Dometic Rooftop RV Air Conditioner
Not cooling
check the and see if the condenser fan is running. you will find it if you take the top off also check and see if the condenser coil is clean. if it is dirty or the fan under the top is not running it will cause the compressor to short cycle on limits or overload.
May 29, 2010 | Dometic Rooftop RV Air Conditioner
Ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Keeps tripping breaker when running ac
you need to check that the breaker it rated high enough for the ac unit
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Not getting cool enough
this sounds like a compressor problem. if the outside coils are getting hot (and properly ventilated) but the inside of the unit is not getting cold then the heat is coming from the compressor.
Jun 28, 2008 | Dometic NDR 1292 Refrigerator
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
