Question about HP 2800DTN Business InkJet Photo Printer
I have an hp business inkjet 2800. It says to Install ink cartridges. They of course are brand new oem cartridges. If I hold down the x button on power up, the printer will come to ready, but anything printed is blank. Also when I try to do a "printhead cleaning". the printer does nothing, just constantly says "cleaning printheads", but it does not move or make any noise. Also in the diagnostic log is a 9002-0003 firmware error.
  • 3 more comments
  • kroper Jul 23, 2009
    I did also replace the printheads and yes the tape was removed. Did not make a difference, printer still will not to the cleaning.
  • kroper Jul 27, 2009
    Is there a reason why the printer will not do the printhead cleaning? Does that have something to do with the logic board also? I can not get the printer to accept the firmware update.
    I replaced the logic board on this printer and I am wondering if I was sent a bad board, or if maybe the problem is not in the board. It says there is no ink, even tho' they are brand new oem. what bothers me is that the "clean printhead" function does not do anything. Do you know what controls this function?
  • kroper Jul 29, 2009
    Is it the logic board that recognizes the ink cartridges?
  • kroper Jul 31, 2009
    I AM WONDERING IF I RECEIVED A BAD BOARD???
  • 453 Answers
I would like to know if the protective covering on the cartridges are removed before installing.
If yes try these steps
It is an internal hardware error message.
We will try a cold reset on the printer with only the power cable connected. By doing so, the printer settings will default to factory settings. Please note that after a cold reset the printer settings will default to factory settings and you may have to re-configure all the settings.
Press and hold the Return and Select buttons, then press Power button to turn on the printer.
If the firmware version is less than 'pmr2006a', try updating the firmware:
Firmware (pmr2006a)
ftp://sbdj:fwdownld@hprc.external.hp.com/bij2800/pmr2006a.exe
Steps to upgrade firmware:
Using the Copy/b command in MS-DOS
To upgrade firmware using the Copy/b command in MS-DOS, follow these steps:
1. Turn off the printer.
2. Connect parallel cable to the printer.
3. Turn on the printer with the Power, Resume, and Select button pressed simultaneously.
4. The LCD screen displays the Flashing mode message AWAITING DATA ON PARALLEL PORT.
5. Type the command in the command prompt:
Copy/b <firmware file> lpt1
6. Wait until the LCD front panel returns to the AWAITING DATA ON PARALLEL PORT message. Normally sectors erase and block program messages are displayed during the process.
7. Turn off and then turn on the printer.
Do not flash the printer in the ready mode.
If the issue persists The printer needs to be serviced as it is a hardware issue. I suggest that you visit our nearest HP Authorized Service Center
Posted on Jul 31, 2009
  • Sai Kiran Camsarapalli Jul 31, 2009
    You may want to try this as well.
    Try using your old printer cartridges on the machine. If they work then contact HP for a replacement of the cartridges.
  • 346 Answers
I take it even config and demo pages are blank? If so then the logic board on the printer is toast and it will need to be replaced.
I would take the cable and try it on a different printer if that is possible. If it works on the other printer then it might be a driver issue.
I have included a page to where you can contact HP directly. I hope this helps. If it is still under warranty I would take advantage of that and have them replace it. Good luck.
http://welcome.hp.com/country/us/en/contact/phone_assist.html#section1
Posted on Jul 27, 2009
  • Joy Shannon
    Joy Shannon Jul 29, 2009
    If you have tried all those things then the next step is to call HP. I can't give you any other advice except what I have already offered. Again here is the link to contact HP directly. They should be able to tell you what is going on. I'm sorry I couldn't give you a solution to this. It has me stumped also.
    http://welcome.hp.com/country/us/en/cont...
    President:
  • 1,197 Answers
"It is an internal hardware error message.
Firmware (pmr2006a)
NOTE: Do not flash the printer in the ready mode.
If the issue persists The printer needs to be serviced as it is a hardware issue. I suggest that you visit our nearest HP Authorized Service Center. To find your nearest Authorized Service Center:
http://welcome.hp.com/country/us/en/wwcontact.html
In the above link select the country > Click on Buy from an HP Preferred Partner > Under "HP Preferred Partner Specialists (pull down menu)" Choose Services - LaserJet Printer Repair (ASDP) > Click the >> button > Under "Please select a vertical market (optional)" Choose Services > Enter the miles closest to your location > Enter street address, town or city and Postal Code > Click Find and verify if there is "APS (HP Accredited Platform Specialist)" in bold letters when you select any HP Preferred Partner from among the search results.
If internal pages are printing fine, then you might have a cable or driver issue.
just to be sure abt whether ur logic board indeed is faulty..... download the updated drivers for ur printer.....
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=3656598
if none of the above works u can be sure that u need to service ur unit....
thank you for using Fixya...
have a nice day and good luck
Posted on Jul 24, 2009
HP 8500 dumped all the ink out of a new cartridge behind cartridge section.
That's unusual but was cartridge properly installed? did it give you any warning msgs? if u are going to install new cartridge, check if installation ok. Then using tool menu, clean and then alligne. Do a test print thru start - printer and dvise tab.
Aug 15, 2013 | HP Business InkJet 2800 Printer
I bought an Inkjet 2800 on ebay which had almost never been used ,it still had the original ink cartridges in which were full. The printer was idle for 3 years and now I can`t get a decent print, All the...
Inkjet printers do not like being unused, especially for years. The print head nozzles get clogged with dried ink when they are unused and even when you insert new ink cartridges the inks won't flow through the nozzles properly. The solution is to replace the print head.
Oct 28, 2010 | HP Business InkJet 2800 Printer
Asking to replace new printheads
is it laser or inkjet, and cartridges are original ones or compatible ones, some printers will not accept comptible cartridges.
May 03, 2010 | HP Business InkJet 2800 Printer
My hp business inkjet 2800 prints blurry even after replacing heads and run heads alignment and cleaning procedure. Is there anything I could do to solve this issue? thanks
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Nov 30, 2009 | HP Business InkJet 2800 Printer
I have not use the HP Inkjet 2800 for over 1 year. The first message reads" replace expired cartridge but when i check all the ink cartridge are nearly full. Please help! Matt S
Some HP cartridges actually have expiry dates on and they will not let you use them past this date. There is no way around this I'm afraid and you will have to purchase a new one. The use by dates are usually well in the future but sometimes if they are old stock or left for a while they can run out.
Sorry to be the bearer of bad news!
Nov 25, 2009 | HP Business InkJet 2800 Printer
Reset hp2800
Hard Reset
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds then replug the power cable to the wall out let and then to the printer.
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the power button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the power button..
Aug 11, 2009 | HP Business InkJet 2800 Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
HP BUSINESS INKJET 2800 SERIES OUT OF THE BOX WON'T PRINT BLACK
Usually this happens when the black cartridge is out of ink or when it is damaged.
Try to print with a new black cartridge
Dec 12, 2008 | HP Business InkJet 2800 Printer
HP Business Inkjet 2800 Problem
there is a sensor which recognises the amount of ink u have in ur cart. if that sensor doesnt work, then printer will not recognise the ink in the cart. Try cleaning the copper contacts on the printer cart slot. if no go. look for service..
Sep 25, 2008 | HP Business InkJet 2800 Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP 2800DTN Business InkJet Photo Printer Logo
2,142 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
