Question about Dell Inspiron 9100 Notebook
Inspiron9100 charges the battery, but does not run off it
Hi, My Inspiron 9100 charges the battery, but when I unplug it from the wall outlet it dies. the indicator for the battery says that it is fully charged.
  • 81 Answers
You've got a dead cell in the battery pack. Replace the cell (there're howto's dotted around the web) or replace the battery pack.
Posted on Jul 21, 2009
Dell Inspiron 1000 won't turn on. It is always
Well if it is always plugged to the wall then the laptop's power jack is the common problem there. You can have a Computer Technician check it and diagnose it for you. Be careful how much you pay, if that is the problem (i'm pretty sure it has to be) you can shop for the part online (ebay is a good place to find them for around ten bucks) and hand it to the computer guy. Otherwise you may be charged a fortune to get it fixed. Next time, use a power surge between the power adapter and the wall's power outlet.
Here's is a brief explanation of what happens with the power jack. Inside of it there are two or three pieces of metal that look like thick wires and what they do is transfer the current to the laptop. Eventually they wear out and break (common cause is having your laptop plugged to the wall continously exposing it to all sorts of power surges). Hope it helps, good luck.
Jan 03, 2010 | Dell Inspiron 1000 Notebook
My dell inspiron 9100 will no longer charge. it was working fine last week. i unplug it and it discharges like normal but when i plug in the cord it says its charging but will not go above the percentage...
Depending on how old the laptop is, the battery may need to be replaced. Since it charges, I would not suspect the power cord, so indications may lead you to requiring a new battery.
Good luck
-Carlos:
Dec 16, 2009 | Dell Inspiron 9100 Notebook
Dell inspiron 9300 doesn't charges i doubt its dc jack is broken , wanna fix it
If it works from DC jack try to change the battery first, for example to the same battery from another comp. If DC jack is broken and laptop don't works from wall outlet better change the jack in service center. Disassembling Dell is hard work... Cheers.
Sep 20, 2009 | Dell Inspiron 9300 Notebook
Hi, The battery light on my Inspiron 6000 flashes 3 times red and then green repeatedly. What does this mean? Also, after the computer is plugged into an outlet for an extended period of time the power...
the battery has reached its expected life, you need to replace it. If it is under warranty, you can call dell and have them replace it. You can still use you laptop with the wall power/charger plugged in, remove the battery to get rid of the flashing red/green light.
Jul 10, 2009 | Dell Inspiron 6000 Notebook
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
No light in the battery indicator when i charge
it must be that the notebook is running on battery or ur battery is fully charged
Thanks for using Fixya
May 06, 2009 | Dell Inspiron 9100 Notebook
Battery percentage is decreasing...
If your battery is a lithium ion battery then according to the folks at Battery University:
"The worst condition is keeping a fully charged battery at elevated temperatures, which is the case with running laptop batteries. If used on main power, the battery inside a laptop will only last for 12-18 months. I must hasten to explain that the pack does not die suddenly but begins with reduced run-times"
see their website at : http://www.batteryuniversity.com/parttwo-34.htm
Hope that helps.
Lori
Mar 13, 2009 | Dell Inspiron E1505 Notebook
A hardware fault
the battery may not be fully charged here is a simply fix use a toothbrush and clean the contacts on the battery and on the computer itself,check also that the blower vents are not blocked and you have good air flow.try again time it see how long it last.Failing that you might have a failing battery.
Good luck
Dec 22, 2008 | Dell Inspiron 9100 XPS Latitude D400...
Dell Inspiron 9100 Notebook Logo
119 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
