Re: I am getting pastel vertical lines down the right...
The TCON board or the LCD panel is Faulty, Can confirm by replacing the TCON board .
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
This problems most likely causes by the board that call the T-CON decodering board.This board sit at the bottom at the middle of the LCD screen panel decodering the codes before sent it to the LCD screen panel for a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual.
it is due to vertical section failure.
please minimise bright to protect crt.
solution.
solution
1 check supply to vertical section.
2 check for ic failure in vertical section
3 check vertical output section parts.
Is it fixable or dumpable?? Please HELP!!!!
yes it is fixable
it is common problem not major one.
good luck.
