Trouble turning tv on
When turning set on the power light comes on and off 3 times and goes out. After 6 to 10 of these 3 try attempts it stays on
  • 8,617 Answers
Sounds like bad capacitors on the RCA itc222 chassis.Need the model number of your set to help
Posted on Jul 22, 2009
TV comes on n goes off,does 3 times
This is the Famous 3 strikes and out for RCA's--it tries to come on 3 times and if fails shutdown occurs.
The high pitched sound may be a short or could be something arcing--if the sound comes from near the very front of set--could be the HV splitter this set has arcing.
Apr 06, 2012 | RCA Televison & Video
My RCA D52W15 52 in. is not turning on. Please help!
Yes, it is not a good set and the situation you indicate means a short exists and the set is following the 3 strikes rule it has--it will attempt to come on 3 times and then go into shutdown.
Apr 03, 2012 | Televison & Video
When I attempt to turn on the TV the green power light will stay on for about 2 seconds. Did system reset with paperclip, timer light flashed for 1 minute. Tried again with same result.
STANDARD ANSWER FOR THIS PROBLEM:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
BEFORE YOU RATE THIS INFORMATION LET ME KNOW WHAT YOU FIND, i AM HERE TOP HELP.
SD TECH
Jul 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I'm having trouble turning on my TV. when I turn it on the green light comes on then goes off a couple of times then goes off. I have to wait a few minutes then try it again a few times before it comes on...
hello my name is rico, you have cold solder in your power supply, you need to open the back of your tv and your tv boards upside down, so you can look cold solder and resolder it, before you damage your tv more. if you need more help, feel free to call me at anytime. 602-810-7149
Jan 07, 2011 | RCA HD52W56 52" Rear Projection HDTV
I have a GE 52 inch projection screen TV. I have replaced three CP's: 150, 114, 120. I also replaced the flyback. The TV worked only a couple of times. I turned it on, then off, and right back on. I only...
You can start with resolder deflection board around Hori output, coils and Big diodes also make sure 2 ribbon connectors are pushed in correctly and in good CK Both Ribbons .
Mar 24, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
RCA Television D52W14
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Jan 08, 2008 | RCA HD50LPW175 50" HDTV
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Electro Med Services...
