X203w shows 'no signal' when booting computer, but then has no display.
  • Fred McCoy
    Fred McCoy May 11, 2010
    When the computer starts, does it eventually show anything? Have you tried another monitor? It sounds like the video card is not operating the monitor. Have you put that monitor on another computer?
  • 528 Answers
The problem might most probably be with the VGA of the PC. Either try another monitor or another VGA card.
Posted on Jul 24, 2009
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
May 19, 2012 | Computers & Internet
After all connection still moniter showing no signal
You either have a problem with the monitor (probably not, since it is displaying a message) or the computer itself. I suspect that your computer is not sending a signal to the monitor. Most of the time this is either a problem with the computer not booting correctly or a video card problem. This is what you should be checking.
Try booting the computer with everything disconnected but the memory and CPU and video adapter. If you still have no signal, try swapping out or removing one stick of memory. If there is still a problem, then it's either the video card or the motherboard (assuming that the power supply is not bad).
Jan 07, 2012 | Computers & Internet
"my pictures" photos of people are shortened and
Tried changing the aspect ratio of the display?
Jan 01, 2011 | Acer X203W 20" LCD Monitor
My acer monitor X203w has a pink rather than white background. That is very annoying. It just started a day or so ago. Is there a simple fix?
The pick tint is caused by the backlights not going to full brightness. It is going to be either the back light tubes or the power supply/inverter board. Your monitor should still be under warranty with Acer so you need to contact them and get it serviced. The longer you wait the worse the tint will be until the monitor quits working all together.
Buddy
Corporate Computer
www.ccl-la.com
Jan 21, 2010 | Acer X203W 20" LCD Monitor
I recently got a 1600x900 monitor and on the display properties there is no 1600x900 option. What do I do
If the monitor came with a drivers or profile disk, make sure to use that. Also, make sure the video card can run at that resolution. Check with the system or video card manufacturer.
You may want to post what kind of (a) system (for instance, "HP Pavilion D1321" (to make one up) ) and/or video card (from display properties - "Plug and play monitor on nVidia MX400") as well.
Oct 03, 2009 | Acer X203W 20" LCD Monitor
Princeton Digital VL1716 Monitor "No Signal Message"
Roxio Changed Your display settings on the dual display.
Right Click on desktop>goto Prefences>
You should see both monitors indentfy the one and change it to a lower resolution.
Apr 28, 2009 | Princeton Digital VL1716 17" LCD Monitor
Pc wont read monitor
If you look at the monitor there will be an led light on the front that is always orange or yellow when the computer is off but still connected to the monitor. This led will turn green when the computer boots up, sometimes even showing a "no signal" display before boot. If you see the 'command line'  text during the boot process (video info, BIOS version, POST text, etc) then the monitor is being recognized by the computer. If that text goes away and the led goes back to orange then it is a driver or operating system problem. Pressing whatever key is prompted at the lower left of the display, if you have a display, like F1, F2, F10, Delete or whatever will get you to the setup program and all is good with the display/computer connection and a green light will stay on. If you never get that green led light then either the video card is bad or not seated properly
Nov 16, 2008 | HP PAVILION A6230N DESKTOP PC
"No Signal" on monitor after boot
hi try to use different slot on your motherboard see if that helps if not try different video card...if that didn't help it might be your motherboard that went bad
Aug 23, 2008 | HP Pavilion a400n (DQ173A#ABA) PC Desktop
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
