Question about Kenmore Washing Machines
My kenmore 110 won't drain, spin or wash, but will fill with water. If I help the tub to spin, it will almost start work. I did hear the motor hum, but not anymore.
  • jeffs214 Jul 22, 2009
    lid switch is ok. I think it has something to do with the mortor freezing up. Still looking for options.
    Thanks
    Genius:
  • 1,122 Answers
Have you checked the lid switch?
Posted on Jul 22, 2009
Kenmore model 110 it will aggitate but will not spin or drain and the motor hums
Eric, it sounds like there may be something stuck in your drain pump motor, or the drain pump motor itself is locked up. If the washer still has water in it, it should not spin.
Nov 30, 2017 | Kenmore Washing Machines
Kenmore 80 series washer model 110 doesn't fully drain when cycle complete
With the lid open, try to turn tub by hand. If you can you may have a bad clutch. If you hear the washer agitating at the begining of the cycle without any water and filling at the end of the cycle, replace the ATC switch. Try spin cycle and open the lid, if you don't see the tub turning, but hear the motor, check motor coupler, or if it never spins after you close lid, check lid switch. These are the most common solutions to this complaint.
Sep 02, 2014 | Washing Machines
Why does my kenmore washer 110 fill with water but won't wash or spin?
Do you happen to hear a humming noise coming from the machine after the tub fills? This might indicate that the motor is spinning, but the belt that connects the motor to the rest of the machine works is broken. It is located underneath the washer. Tip the washer a bit and have a look. If it's broken, you'll probably find the belt laying on the floor. Take that to an appliance parts store where they can match it up with a new one. Installation is not too difficult. The belt will go around the motor pulley, the transmission pulley, the water pump, and in some cases, a spring-loaded tensioner. I hope this helps! :) -Jason
May 06, 2014 | Kenmore 22422 Top Load Washer
Washing machine will not drain water
Here are some basic troubleshooting steps you can follow to help you determine why your washing machine won't drain:
1. Check the drain hose in the back of the machine and make sure it isn't kinked or flattened.
2. If it spins but won't drain, there could be a piece of fabric stuck between the inner and outer tub, or even the drain hose or pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. It could also be a faulty timer.
3. Are clothes soaked at the end of the wash, even though it appears to go through the spin and drain cycles? Worn or loose belts could be the culprit.
4. When the spin cycle starts, do you hear a humming noise? It could be a faulty or jammed impeller pump.
For more suggestions on troubleshooting and fixing this issue, check out Washing machine not draining. I hope this helps!
Sep 11, 2012 | Whirlpool Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Kenmore 23012, spin cycle problem
This sounds like a broken coupler gear. I'm having the same problem with my Kenmore-80 Series. The machine fill up, pump out, but when I try to spin I get nothing and the I can hear the motor humming/grinding. I've heard the coupler gear is not expensive $35 or so and the repair procedure is not difficult, but I can't locate how to fix it. If you find any additional information, please send my way. I don't want to pay $150 or so to have it serviced.
Mar 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 110 Series will not agitate, spin or drain but will fill
you may find that the motor is not going because of faulty capacitor or faulty timer
remove the motor from machine and try running with no loadif it works them maybe the pump is jammed or worse still gearbox is faulty
Jan 28, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
61 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
