Question about Dehumidifiers
Dehumidifier. #857-0152-0000
Dehumidifiermodel857-9925-00 electric motor burnt out
  • 614 Answers
Get your make and model number Google dehumidifier parts and go to parts web site they will sell you a new motor. But sometimes the motro will cost you as much as new dehumidifier,. Russ
Posted on Jul 22, 2009
Motor burn out
I think so. I believe the motor failed while there was water in the bucket. Over time the mold started growing, it was consuming the dirt on the inside of the bucket and utilizing the water contained therein.
Mar 22, 2014 | Whirlpool Dehumidifiers
I smell a burning odor from dehumidifier
dear sir
first remove i,ts main electric supply cord and open control box and all wire and device check by electric tester care fully if there is any wire is burnt and damage then find out burnt/damage device or wire. and it s up to if you can repair by yourself or contact to product,s technician for further action.
hope answer the question
thank you
please vote!
Oct 03, 2010 | Maytag M7DH45B2A Dehumidifier
Breaker blows when dehumidifier tries to kick on? Replaced capacitor and no change does this mean the compressor is junk?
One of the major faults with dehumidifiers is damage and electrical ''tracking'' caused by the dampness they are constantly exposed to. Isolate the supply completely ! from the unit then carefully inspect all electrical parts for corrosion and ''blow'' marks. Check motor for shorts to earth as this occurs on old elec motor windings. Also inspect carefully the control contactor / relays that switch motor and fans.
Jul 21, 2010 | Haier Dehumidifiers
Fan will not run
It's probably a common problem with these models: the fan motor causing a thermal cut off fuse to blow. I have the same problem. See this link on another site: http://forum.doityourself.com/humidifiers-dehumidifiers/177549-kenmore-dehumidifier-fan-stopped.html
Jun 23, 2010 | Kenmore 54351 Dehumidifier
HOW DO I OIL THE FAN MOTOR FOR A WHIRLPOOL MODEL aha-015-20 DEHUMIDIFIER?
Look on the each end of the motor. If you see a rubber plug that you can remove then it can be oiled. More than likely you will find none. The vast majority of electric motors today are sealed for life and there is no provision to add oil.
Jun 06, 2010 | Whirlpool AD50DSL Dehumidifier
Amcor dehumidifier motor running very slowly
Hello Filter neglect is a popular cause of problems.20yrs you got your moneys worth the unit dosent owe you a thing.Burning smells sounds dangerous.Please look into replacement.
Mar 31, 2010 | Dehumidifiers
AMCOR SD10 Dehumidifier, Need to replace the electric fan motor.
Take it out, and search the part number on line, they are bout $40 with s/h. however my current discovery:
It made no sense to me that despite no visual issues, the fan motor is bad. So, with further research it turns out that the true culprit is the small thermistor/thermal fuse between the orange wire (ground) and motor winding wire. The thermistor is taped underneath the silver aluminium and yellow tape on the fan motor. I heard about this bad (open/no continuity) thermistor makes almost >99% of the fan motor problem regardless of any brand name because this cheap c-fram fan motor is NOT made in USA. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a thermistor or type of temperature sensor connected between the orange wire and a motor winding wire. On my motor this was no longer working.
The part marked "JET 123 NM1 2A 130C" is a thermal fuse. The 130C is the temperature rating. When the motor get hot (130C / 265F) the fuse opens. The circuit is broken and the motor stops.
The motor is still good. The fuse is blown. It must be replaced to get the motor running again. You could bypass the fuse but then you invite a fire hazard.
A replacement fuse is available from Digi-Key. It is a Cantherm SDJ1 DF128S (128C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1133-ND
Part cost 98 cents
You might want to go with the next higher temp (141C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1134-ND
Dec 30, 2009 | Amcor Dehumidifiers
Motor will not cut on
check the motor resistance, check the connection to the motor. Thermistor may be cut the connection.
Jun 14, 2009 | DeLonghi DE500 Dehumidifier
Fan motor doesn't run.
You're gonna have to do a little work but there should be and electric motor shop in any large city that can rebuild YOUR motor. (found quite a few listed under <electric motor> in the GR,MI yellow pages)
Jun 06, 2009 | Edison 40 Pint Dehumidifier
Dehumidifiers Logo
111 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
